June 23, 2018, 02:41:01 PM
Author Topic: Oil Filter Wrench  (Read 4287 times)
Offline opus
Oil Filter Wrench
« on: June 20, 2014, 04:28:50 AM »
Whats the favorite oil filter wrench used here?
Offline Dave5Cs
Re: Oil Filter Wrench
« Reply #1 on: June 20, 2014, 04:31:37 AM »
Very large channel locs ;D
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
Offline sparkplug188
  • 1979 Model 5 Eagle - 45/102 8v92 HT740
« Reply #2 on: June 20, 2014, 04:32:04 AM »
Offline opus
« Reply #3 on: June 20, 2014, 04:32:52 AM »
Yeah, wont work for me.  I need something to reach up.  Cant get at it laterally.
Offline bevans6
  • 1980 MCI MC-5C
« Reply #4 on: June 20, 2014, 09:37:53 AM »
I use one of the ones that have a length of bicycle chain and a hook.
Offline sledhead
dave , karen
Online Oonrahnjay
« Reply #6 on: June 20, 2014, 12:19:19 PM »
    I have a set of these.  One for the canister cap in the TDI in my VW and a larger one for the bus engine; the swivel at the pivot lets it work at any angle.   Works like a charm - I don't really need the swivel feature in the bus but it's necessary on the VW.  I think the set was about $22 but I saw them for less at either Harbor F or Northern Tool (one of the cheapo places).
http://s45.photobucket.com/user/oonrahnjay/media/Jetta/Wrench_zps7432bfe1.png.html?sort=3&o=0
« Last Edit: June 20, 2014, 12:21:05 PM by Oonrahnjay »
6-cyl, 4-stroke, Leyland O-680 engine
Offline bronson
  • Jr. Member
« Reply #7 on: June 20, 2014, 12:59:24 PM »
Here is what I recommend http://www.amazon.com/HD-Oil-Filter-Strap-Wrench/dp/B000I1APIS
Similar to what Dave uses. Had one identical to his until I ran into a large filter someone over torqued and the strap pulled from the tubing. The strap slides into a notch in the tubing and will pull out under too much pressure on large filters. If your using it only on filters you installed it would be fine
« Last Edit: June 20, 2014, 01:02:08 PM by bronson »
Gary Bronson
1984-MCI-9
Mount Orab Ohio
Online Oonrahnjay
« Reply #8 on: June 20, 2014, 01:06:47 PM »
    Or you could take a worn-out or cracked deep socket (I'd look for a 3/8" drive) and grind two 1" long slots in it and find a strap from an old motorcycle tie down or an old belt.  Total price $0.00.
Online chessie4905
« Reply #9 on: June 20, 2014, 01:52:56 PM »
    Or... you could change back to the cannister with element and use a 3/4 inch socket with ratchet. Much cheaper elements, although can be messier job without drain in cannister. They also make a metal strap type thapretty compact. Those webbing type tend to slip if filter is oily; you know, like on a DDC 2 cycle.
Offline opus
« Reply #10 on: June 20, 2014, 02:38:06 PM »
I had one identical to Dave's too.  Thats why I am getting suggestions, so I dont have to break another one.
Offline eagle19952
« Reply #11 on: June 20, 2014, 03:06:50 PM »
I got mine from Caterpillar years ago, you can get them lots of places now, I'll buy you a new one and a quart of your favorite bourbon if you can break it, removing a filter...:)
« Last Edit: June 20, 2014, 03:13:25 PM by eagle19952 »
« Reply #12 on: June 20, 2014, 03:20:35 PM »
I have the strap type. Always able to get the filter off. It will crush the spin on filter, but you're throwing the filter away anyway. The main trick to getting a spin on filter off is not to tighten to tight in the first place. Just tighten with hand pressure, never use a filter wrench to tighten. Good Luck, TomC
Offline opus
« Reply #13 on: June 20, 2014, 04:33:56 PM »
Yeah, you know how people listen to that.  If a little tight is good, a lot of tight is better.  ;)
Offline Dave5Cs
« Reply #14 on: June 20, 2014, 11:38:27 PM »
says right on the bottom of the filter,"hand tighten + 1/8". But that is really misleading because everyone has a different grip!... :o
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
