How is your bank made up? 6es 12ves or 24s? If 6 or 12 it can be wired to be charged with the 12 volt system and costs little to do.>>>Dan ( the 12 volt starter battery for the generator can be stand alone)
Why are youall making this so complicated ?Lostranger has 4 12 volt batteries and a 12 volt source on the APU which is (or better be) isolated from his coach's 24 volt system. Just run positive and negative directly to the 4 batteries - 2 wires in parallel along with voltage regulation and, if needed, isolation.edward
