Author Topic: Continually Blowing my Top - A/C cover  (Read 3210 times)
Offline plyonsMC9
  • Global Moderator
  • Big Wheels Turnin'
    • PhilLyons.com
« on: July 15, 2014, 10:10:26 PM »
Greetings All,
So, over the past 4 - 5 years I've lost 4 front a/c covers.  For the first 5 years of the Penguin Duo-Therm 13.5 btu front a/c I had no problems.
After the last loss in high winds we decided to replace the front a/c with a new low profile Coleman mach 8 15k btu a/c, thinking along the lines that with the lower profile and the fact that the shroud goes almost all the way down there will be less chance of having the wind rip off yet another, and maybe causing an accident.  The Penguin a/c has the shrouds which only seem to cover about 1/2 of the a/c unit.
Haven't replaced it yet - is my logic totally bogus?  Everyone I talk with says that they haven't seen anything like this.  Just what I don't want to hear.
My plan is to replace the unit this Thursday.
What say my fellow bus folk?
Kind Regards, Phil
Northern Arizona / 1983 - MC9
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
Re: Continually Blowing my Top - A/C cover
« Reply #1 on: July 16, 2014, 05:36:52 AM »
I say good luck. I have no experience with rooftop ac, but your logic seems sound to me.
Offline belfert
« Reply #2 on: July 16, 2014, 05:45:11 AM »
A company in Canada makes heavy duty shrouds for rooftop A/C units including the Dometic Penguin.  I paid just over $100 for one for a Penguin.
It turned out my Penguin A/C unit was junk so i still have the shroud never used I will sell cheap.  I'm not sure if it is in my bus, or if it is in my storage container.
Offline dukegrad98
« Reply #3 on: July 16, 2014, 06:00:12 AM »
The logic seems sound.  I don't know anything about rooftop AC units, but my family plays a game when we take long road trips of counting the shrouds we see along the side of the road.  It appears that those things blow off all the time.  Between here (East Texas) and Colorado, it's pretty ordinary to count 3-4 per drive.
Cheers, John
Online luvrbus
« Reply #4 on: July 16, 2014, 06:13:17 AM »
The front cover always blows off here in the AZ from the sun and wind,the new Penguins 11 units have a heavier cover about a 1/4 inch thick made of fiberglass they should hold up.
I installed one to replace the older Penguin we had, the older unit cooled a lot better than this new Penguin but I like the features of the inside cover better than the older Penguins
Online Dave5Cs
  • 1979 MCI MC5Cs 6V-71,644MT Allison, Roseville, CA
Re: Re: Continually Blowing my Top - A/C cover
« Reply #5 on: July 16, 2014, 06:31:30 AM »
Phil slow down. Take the screws out of the top and put them back in with 2" fender washers. Seems to hold them down pretty well.
Dave5Cs
"PATHFINDER" (PFBus)
 1998 Jeep TJ (PFTOED)
 Congressmen should wear uniforms,
 like NASCAR drivers, so we could
 identify their corporate sponsors
Online luvrbus
« Reply #6 on: July 16, 2014, 06:40:27 AM »
I use 2 stainless straps 2 inches wide 1/8th thick from Ace across the top it seems to work
Offline bevans6
  • 1980 MCI MC-5C
« Reply #7 on: July 16, 2014, 07:17:55 AM »
I read this and said "holy snappin', he could pick up the front of the bus with those straps"  "Nah, that's just dreamin..."  So I did the math.  2" by .125" is .25" cross section, ultimate tensile strength of 304 stainless is around 73Kpsi, so two straps is 36,500 lbs of load limit.  More than my bus weighs, let alone the front axle weight!   ;D  I suspect finding something to bolt the straps to would be the challenge...  The AC unit probably won't take the strain...   :o
Offline lvmci
« Reply #8 on: July 16, 2014, 07:28:32 AM »
Hi All, Ive always seen drying cracking, here in the south west as the reason for replacement, which were thicker and more reinforced, one of my trailers had an aluminum cover over the AC! Lvmci...
MCI 102C3 8V92, Allison HT740
Online luvrbus
« Reply #9 on: July 16, 2014, 07:29:07 AM »
I don't get into the math Brian just what works I just drill the holes to match the bolts on top of the AC I use S/S to prevent rust streaks running down on the side of the bus the 1/8th is not much thicker than the washers under the nuts and 1/8th inch won't rattle BTDT with the 1/16th steel straps, take 2 pieces 22 inches long for the Coleman a little less for a Penguin
« Last Edit: July 16, 2014, 07:34:34 AM by luvrbus »
Offline bevans6
  • 1980 MCI MC-5C
« Reply #10 on: July 16, 2014, 07:51:08 AM »
I'm always in favor of doing what works!  My mind just asks me funny questions sometimes - "I wonder if you could pick up a bus by the rooftop AC cover?  Lets find out!"
Offline plyonsMC9
  • Global Moderator
    • PhilLyons.com
« Reply #11 on: July 16, 2014, 12:28:42 PM »
LOL, this is one wild thread!!  Thanks for all the feedback.
I had moved to using fender washers.  Very interesting on how many folks spy these covers by the side of the road.  Hmm, more travel amusement - but kind of scary.  We were concerned about the cover flying off & causing an accident behind us.
The Mach 8 uses a different bolt pattern, one in the front of the A/C, 4 on top.  Don't see any bolts/screws on the sides.  Colman use what look to be fender washers.  One other idea I had heard of was to reinforce the screw holes with fiberglass (cloth?) and epoxy, then drill through it.  Though, if too much reinforcement, airlifting the bus may be an issue?  Maybe I just won't use the stainless steel straps to avoid that concern.  Seriously, the strap sounds like a good idea.
I've attached the coleman mach  8 view, vs. our current penguin shroud view.
Kind Regards, Phil
Offline belfert
« Reply #12 on: July 16, 2014, 12:52:11 PM »
Personally, I would try one of the heavier duty ICON replacement shrouds before buying a whole new rooftop unit.
Online luvrbus
« Reply #13 on: July 16, 2014, 12:57:22 PM »
I doubt you find that model of Penguin unless it is old stock the newer ones have a different setup for a cowling
Offline plyonsMC9
  • Global Moderator
    • PhilLyons.com
« Reply #14 on: July 16, 2014, 01:07:41 PM »
Thanks Brian - the front unit after 10 years seems to have developed a couple of issues, and I'm tired of fighting it.  The train of a/c cover replacements is the last straw.  Want to get slightly higher btu cooling up front & better cover layout.
However, we do have 2 other a/c units, penguin, etc.
Is this the company you refer to, ICON:
http://www.icondirect.com/
Other 2 unit covers showing age now and it seems that if I have the correct web site, the prices are lower for a better cover.  Correct?  I would like to fix them before they fly away
Unless my 10 yr old models aren't covered by ICON (no pun intended).
Kind Regards, Phil
