Author Topic: voltage regulator that last  (Read 2240 times)
Offline olebusman
  • Jr. Member
« on: January 25, 2015, 11:09:03 AM »
  Hi all  A quick question, does anybody know of a electronic regulator for a 12 volt DN50 alternator, that will last? I have been using a Transpo V1200 regulator and have replaced 2 with another bad also 1 Balmar ARS-5. I think the amp output of these regulators is marginal at best. What is the rotor draw on a DN50? I don't want a 3 stage as I run the gen most of the time on the road so the new Balmar MC-614 is a little expensive for what I need. Thanks for the help  olebusman
Offline bevans6
  • 1980 MCI MC-5C
Re: voltage regulator that last
« Reply #1 on: January 25, 2015, 12:24:08 PM »
Have you tried a Delco 50VR?  It's the regulator designed for the 50DN.
Offline Melbo
  • MC8 under construction
« Reply #2 on: January 25, 2015, 02:41:48 PM »
Everyone's set up is different.  I have a magnum 4024 that my generator runs while on the road.  I had (the operative word here is had) an isolator in the system and had to replace the regulator a couple of times.  I went to a solenoid set up that I control with switches from the dash and I have not had any recent issues (knock on wood) with my regulator. I think that some types of electronics don't play well together and with each bus being set up differently it is hard to guess exactly what causes problems.
YMMV
HTH
Melbo
Offline olebusman
  • Jr. Member
Re:a voltage regulator that will last
« Reply #3 on: January 25, 2015, 03:12:11 PM »
 Brian  I think the delco regulator is just 24 volts???
Melbo, I have a solenoid (big boy) for my system which has worked great. Just the regulators say they are good for 8 amps on the field terminal which I think is marginal. The balmar mc-614 says it is good for 15 amps on the field bot it is $300.00 and I don't need a 3 stage. Can't seem to find something to work.  olebusman
Offline bevans6
  • 1980 MCI MC-5C
« Reply #4 on: January 26, 2015, 03:20:11 AM »
There are two models of the current 50VR, it's the same model name for both but different part numbers.
http://www.elreg.com/10503807-50dn-generator-oem-delco-regulators-12v.html
Offline olebusman
  • Jr. Member
« Reply #5 on: January 26, 2015, 07:46:04 AM »
 Thanks Brian   I should have seen that.  Trying to locate one now.  Thank you for pointing out the two part nos.  thank you again  olebusman
