Author Topic: hydraulic leveling mci-9  (Read 4968 times)
Offline doublee
  • Jr. Member
  • Osgood, IN
« on: June 12, 2015, 03:24:57 PM »
  I was in the process last year of starting to figure out where to mount my homemade hyd levelers  but once I removed my duals and tags I ended up replacing all
my airbags, rod bushings, airlines,  brake Actuators, level valves rebuilding the dd3 cans and dryer and a slew of other crap, so by the time I got that done I ran at of time to work on the hyd. levelers so I was wondering if anybody had any pics of there hydraulics mounted on the mci-9. I'm getting my info for this fall so I can try it again.
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
Re: hydraulic leveling mci-9
« Reply #1 on: June 12, 2015, 04:29:45 PM »
Interested in this too. Subscribed :)
Offline doublee
  • Jr. Member
  • Osgood, IN
« Reply #2 on: June 12, 2015, 05:07:34 PM »
well here is what I have so far the cylinders I found are 3" bore 2"rod 18" stroke
I made the ends pivot (forget the degrees of pivot ) I just need to weld a disk on the end.
I found a new pump and auto level set a 2500 psi forget the name right now its packed away.
I have to get my head wrapped back around this its been a year since I played with it.
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #3 on: June 14, 2015, 02:43:35 PM »
Hey is 18" stroke enough? I am just thinking out loud here while on medication for a majorly injured ankle...so take this with a grain of salt:
1. Distance piston has to travel to reach the ground.
2. Distance piston must travel to level coach
What's typical?
Offline doublee
  • Jr. Member
  • Osgood, IN
« Reply #4 on: June 15, 2015, 01:05:18 PM »
 when I started this I talked to bigfoot and that is what size they use for the mci $$$$$
 the cylinder with foot, retracted is 27" long I don't know if it will fit in the front.
Offline doublee
  • Jr. Member
  • Osgood, IN
« Reply #5 on: June 15, 2015, 01:12:50 PM »
 sorry I forgot the rest of it
 should take less than 8" to the ground and 10" off lift according to them
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #6 on: June 15, 2015, 01:49:25 PM »
Oh ok. 10" should lift the wheels off ground if needed
Offline doublee
  • Jr. Member
  • Osgood, IN
« Reply #7 on: June 15, 2015, 01:53:13 PM »
yes and I forgot that those numbers are with the bags dumped
I think you could get away with 6" to the ground with the bags dumped
I hope somebody post some pics here
Offline BRUISER
    • iMPAKS
« Reply #8 on: June 16, 2015, 01:50:06 PM »
I have been wanting to do the same and my biggest question is also where to mount the rams?
my thought is two in the front near the front tire/front axle area and then in then 2 in the rear near drive axle.. my thought is since the wheels are the only thing touching the ground in that area then the rams should be fine also
iMPAKS.com
Raleigh, NC
1983 MCI MC-9
Offline doublee
  • Jr. Member
  • Osgood, IN
« Reply #9 on: June 17, 2015, 07:04:31 AM »
 my thought  was to mount a plate  in place of the round retainers that hold the suspension rods.  That would be 4, 3/4 bolts per jack  and the shear strength for a grade 2 is more than the bus weight, let along 4 grade 8 bolts per jack this is for the rear only
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #10 on: June 17, 2015, 07:32:52 AM »
Does know one on here have an MCI with leveling jacks installed that could post some pics?
Offline doublee
  • Jr. Member
  • Osgood, IN
« Reply #11 on: June 17, 2015, 07:34:38 AM »
 hi BRUISER  I see that you are into offroading  that was the main reason we got the bus here is a pic of use getting ready to leave for brimstone
Offline bevans6
  • 1980 MCI MC-5C
« Reply #12 on: June 17, 2015, 07:41:22 AM »
I would go with one ram in the middle of the front bay, and one on each side of the rears near the jacking points.  That way you don't torque the bus as it goes up - with four rams it is guaranteed to not go up level and square.
Offline doublee
  • Jr. Member
  • Osgood, IN
« Reply #13 on: June 17, 2015, 07:41:53 AM »
I know Scott I thought for sure somebody would have some pics.
Offline doublee
  • Jr. Member
  • Osgood, IN
« Reply #14 on: June 23, 2015, 11:10:18 AM »
 does anybody know somebody that can get some pictures
