Author Topic: Engine is TOASTED  (Read 72178 times)
Re: Engine is TOASTED
« Reply #135 on: September 06, 2015, 05:54:58 AM »
Yep that engine was too clean around around the exhaust and turbo area to have serious problems.I still don't believe he has a problem that maybe a set of injectors and tune up won't cure,a simple air gap adjustment could cause his symptoms
Offline eagle19952
« Reply #136 on: September 06, 2015, 09:16:49 AM »
i am super curious as to why he had a recommended DD wrench to look the problem over and drove away...
what's up Sean ?
Offline Seangie
  • www.herdofturtles.org
    • Herd of Turtles
Re: Re: Engine is TOASTED
« Reply #137 on: September 06, 2015, 10:09:39 PM »
what's up Sean ?
Don,
I had the reccomended DD wrench in Spokane look it over.
It worked out great.  Damian was solid and was very helpful.
On the other hand the problem returned.  It appears to be a transmission problem.  Ill post more about it later.
We are currently fine and will have the transmission looked at when we get to Portland Area.
Ill update on that in November when we get there.
Thanks guys.
'Cause you know we,
Driving through the night
To that old promised land'
Offline eagle19952
« Reply #138 on: September 07, 2015, 10:07:15 AM »
see, Prayer works  ;D
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #139 on: September 07, 2015, 12:15:20 PM »
If he needs a in frame I know a guy that has a set of 6v92 Detroit liners and pistons huh Scott  ;D
Lol. It crossed my mind.....that would hopefully give us a lifetime supply of good bus karma lol. But I don't believe in Karma so not sure where that leaves us. Trans issue should be less $$. Keep us updated shanks
« Reply #140 on: September 07, 2015, 01:58:44 PM »
Just curious why do think it's the transmission not much goes wrong with a 740 the governor and modulator go sometimes causing a few problems
Offline B_K
« Reply #141 on: September 08, 2015, 08:31:22 AM »
"The Don" Fairchild is working an Vegas these days and not only is he 2 Stroke Detroit awesome!
But he's Allison certified too!
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #142 on: September 08, 2015, 01:55:51 PM »
Shanks, I know this is really elementary, but my 9 was running terribly and zero power until we finally realized the fuel filters were the wrong micron rating. Just a thought
Offline Seangie
    • Herd of Turtles
Re:
« Reply #143 on: September 13, 2015, 07:21:06 PM »
Scott - Just replaced the filters.  Pretty sure its the tranny.
'Cause you know we,
Offline Seangie
    • Herd of Turtles
« Reply #144 on: September 13, 2015, 07:22:13 PM »
BK - if "The Don" is indeed in Vegas its definitely worth a visit.  How do I find him?
;D  BK  ;D
'Cause you know we,
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
« Reply #145 on: September 13, 2015, 08:44:24 PM »
Sean -
I sent you a text message. . .
« Reply #146 on: September 14, 2015, 05:31:36 AM »
 ;D Don told me the other day he is not even interesting in working on buses anymore,I am trying to help him sell his CC he wants to move into a house in Vegas
