Author Topic: Steering wheel angle  (Read 10989 times)
Offline Darkspeed
« on: October 27, 2015, 04:07:02 AM »
I know most of the older buses have a fixed steering wheel but is there a reason for the flatter horizontal orientation of the steering wheel?
Is it to get better leverage on the steering back when it required muscle to steer with a giant steering wheel?
Is there anything wrong with having a more modern vertical orientation if one has good power steering and an 18" wheel?
Is the horizontal position more comfortable for long distance driving? To me it seems like the vertical position would be more comfortable..
I have a tilt telescoping steering column and 18" wheel and im getting ready to locate it and I am trying to decide on an angle for the center of the tilt range.
It's all math and metal...
Offline uncle ned
    • Visit: Busconversionstuff.com
Re: Steering wheel angle
« Reply #1 on: October 27, 2015, 04:10:19 AM »
With the power steering you are putting on your bus.  Use a good tilt . It makes driving so much better and a lot easier for us old people
to get in and out from behind the wheel.
uncle ned
4104's forever
6v92 v730
Huggy Bear
Offline Darkspeed
« Reply #2 on: October 27, 2015, 04:14:43 AM »
Ned , I did not even think of that..
Im using a 2015 freightliner cascadia steering column and in the up tilt position the steering wheel is completely flat and way forward, now i know why....
I will rename that the McDonalds position..
« Reply #3 on: October 27, 2015, 04:48:39 AM »
If for some reason you blow the power steering, you'll be greatful for the horizontal choice of steering wheel. I personally like the flat steering on my transit. Good Luck, TomC
Offline HB of CJ
Design Philosophy?
« Reply #4 on: October 27, 2015, 05:59:54 AM »
Design and operation philosophy?  How often is full integral power steering going to totally fail?  Extinct old Crown Supercoach school buses and most if not all new fire apparatus has a fall back system where if the primary power assist fails the vehicle can still be safely stopped or even driven if need be.
With a small tilt extend neat nice steering column and wheel, do understand that if your integral full power steering fails you are dead in the water.  Or along side the road.  If you can get off the road.  Still steer the Bus Conversion?  No.  Even I could not.  Something to consider.  An engineering point of view.
Offline Darkspeed
Re: Design Philosophy?
« Reply #5 on: October 27, 2015, 06:16:52 AM »
Interesting point..
Most modern semi trucks and class a motorhomes have tilt telescoping columns and im pretty sure the ross gear + 18" wheel would be considered the standard.
What do they do in a primary power assist failure?
Is modern power steering most often a slow failure or a total crap out.. assuming you dont cut/rupture a line.
Offline HB of CJ
« Reply #6 on: October 27, 2015, 07:06:19 AM »
Lots of modern stuff has built in POTENTIAL weaknesses.  99.98% of the time nothing happens bad because nothing happens.  Perhaps a better word would be technology.
One older point of view would be ... "the fancier they make the plumbing ... the easier it is to stop up the pipes".  This always has been a potential with modern stuff like power steering.
Practically every vehicle today, large or small, has full power steering.  A few exceptions.  Such systems are extremely reliable.  They rarely fail.  But when they do? Yikes!
Another non related example would be the computer controlled fuel injection and emission systems.  Extremely reliable and efficient.  They work.  But if only one fuze blows?
How non likely is it that entire systems could fail?  Practically zero.  But ... all it would take is one big H bomb EMP device 1000 miles over Omaha NB to bring down the nation.
Back to full integral power steering.  Along with automatic transmissions, they are the normal thing to have today.  I suppose it depends upon your point of view.  Very nice to have.
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
« Reply #7 on: October 27, 2015, 07:22:56 AM »
Todd -
If you were to be rollin' down the super slab at 60 mph and the engine quit, you'd very quickly appreciate the OEM 22" steering wheel!
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #8 on: October 27, 2015, 07:46:45 AM »
Todd -
This ^ much more likely. I've experienced it several times as a matter of fact. But once stopped, even with the big wheel, you're not turning it much....call a tow truck
Offline Darkspeed
« Reply #9 on: October 27, 2015, 07:57:53 AM »
When I bought my 4106 I moved it with no power steering and it was like turning a battle ship, im not sure I would want to get over 30mph like that.
What do all of you folks with your tilt steering / steering wheel upgrades do in an emergency?
Anyone been hurt by this?
Offline kyle4501
  • NEWELL in South Carolina
« Reply #10 on: October 27, 2015, 08:05:01 AM »
The larger the wheel, the less force required at the rim to provide the same torque input to the steering box.
(Another way to look at it - the less force to your hands as a result of reflected torque from debris, potholes, etc)
An old engineer that worked on bus steering gear boxes mentioned that you aren't going to be able to do much steering with freshly broken hands - a very possible result the wheel unexpectedly spins in your hands - as a result of reflected torque from road conditions.
BTW, front wheel alignment is usually different for manual steering - almost no caster or camber when compared to power steering settings.
It was rare for a Trailways bus to have power steering & they made it from one terminal to the next. . . .
Offline Iceni John
« Reply #11 on: October 27, 2015, 08:21:37 AM »
Some years ago the high-pressure hydraulic hose to my fan motor split, resulting in all the ATF that supplies the fan and the power steering dumping out on the road.   I could muscle the bus off the freeway and into a gas station parking lot, but it was HARD WORK !   As far as I'm concerned, my bus is not drivable without power steering.   Maybe going down the freeway at 60 MPH it would be OK, but at lower speeds it's arduous.   I keep my steering wheel at about 15 degrees back from horizontal so I can muscle it in an emergency, and it just feels nicer at that angle anyway.   I've noticed that some of the new Thomas buses have their wheels at about a 45 degree angle  -  I think that would feel strange.
I've sometimes wondered how so many older British buses and coaches managed without power steering, but I think (on seeing videos of them being driven) that they had much lower-geared steering.   However, wrestling a heavily-loaded double-decker front-engine bus through narrow city streets would have been a workout.
2kW of tiltable solar.
Offline Lin
  • 1965 MC-5a
« Reply #12 on: October 27, 2015, 09:21:42 AM »
I have an 18 inch wheel on an adjustable column with power assist.  I do keep some tilt in the wheel for comfort while driving.  I can not see spending years of driving in a less comfortable, and therefore less safe, position waiting for a particular failure.  I believe that, if the system failed I would be able to get it to the side of the road-- that's all I would want to do.
If you have a tilt wheel, maybe you could use it to maximize your comfort for now and flip the wheel to horizontal should you need it.  Also it would be good motivation to stay on top of preventive maintenance on your steering system.
Offline HB of CJ
« Reply #13 on: October 27, 2015, 10:54:12 AM »
Sometimes older may be better?  Back in 2001 when driving my new to me then Crown Supercoach ex schoolie from Apple Valley CA to Cave Junction OR, the Victors VT42 power steering pump totally failed North of Sacramento on Interstate Five.  Locked up tight.  Oil everywhere.  Yikes!
Since I had thoughtfully failed to provide an adequate trip repair kit, I just cut the belts and drove the Crown home with manual steering.  I had power assist, not integral power steering.  Designed that way for a purpose.  At highway speed the TRW Armstrong steering felt the same.
I drove her a bit that way, then found and hung a larger proper pump for the 16K front axle along with new long hoses.   If I had had full integral power steering, things would have turned out very different.  Again, different design philosophies.  I guess it depends upon personal experience.
Offline Jim Eh.
  • Excess in moderation
« Reply #14 on: October 27, 2015, 11:27:24 AM »
Things like near zero camber and caster settings along with the angle of the king pin/ball joints, a thing called "included angle" all have a factor on how manageable standard steering is or not. They are mucho different in a vehicle with power steering.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
