Author Topic: 1988 MCI Bus Entrance Door  (Read 1894 times)
Offline roadmangler
« on: August 23, 2016, 05:25:23 PM »
Hi Everybody
    I have a 1988 MCI bus conversion with a problem the switches for the entrance door do not work. I was on a website called FYI from MCI, it said to check fuse F15. Where would I find this fuse?
                                                      Thanks for your help
        MAX
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
Re: 1988 MCI Bus Entrance Door
« Reply #1 on: August 26, 2016, 06:08:59 AM »
Should be in the drivers side electrical panel, I would think. Check your manual.
What model is it?
Offline roadmangler
« Reply #2 on: August 26, 2016, 06:28:37 AM »
Good Morning Grumpy
      Its a 96 A3
Offline roadmangler
« Reply #3 on: August 26, 2016, 06:31:36 AM »
I mean Gumpy
Offline thomasinnv
  • Derrick Thomas
Re:
« Reply #4 on: August 26, 2016, 06:43:44 AM »
Open the access door under the driver window. You might get lucky and find a decal on the inside of the door with the fuse location. Fyi the main disconnect has to be on for the door switch to have power.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
