Author Topic: Suburban furnace fan lubrication  (Read 2863 times)
Offline richard5933
Re: Suburban furnace fan lubrication
« Reply #15 on: November 04, 2017, 03:06:36 PM »
Look up Suburban RV furnaces. They still have that model in identical dimensions and port locations.
I've searched all over for that. The closest I've found is the NT-34SP. it's close but not the same. Did you find a replacement for the NT-32CD that was the same size? Love to know where you saw that if you did, as I've searched high and low and haven't found it yet.
1974 GMC P8M4108a-125 (Current Bus)
KD9GRB
Offline chessie4905
« Reply #16 on: November 04, 2017, 06:58:07 PM »
Give them a phone call. If they carry blower motors and combustion Chambers, then fix it. If it is early one of uncommon standard dimensions, then bite the bullet and upgrade. Either company or major dealer should be able to recommend which model would replace it best. At least then you can make your installation more serviceable. Is that plywood behind it removeable from other side?
Offline Dave5Cs
« Reply #17 on: November 04, 2017, 07:15:11 PM »
"PATHFINDER" (PFBus)
 1998 Jeep TJ (PFTOED)
Offline eagle19952
« Reply #18 on: November 04, 2017, 08:49:00 PM »
then parts should be a piece of cake...
Offline richard5933
« Reply #19 on: November 05, 2017, 03:39:57 AM »
The model we have was made in the 70s. They still have similar model, but there are enough changes to make it not be so simple.
I'll be tearing into the project this week if the weather holds. Once I get the furnace pulled out I'll be able to make a better decision. Unless the motor can be made to work, then replacing at least the motor will be necessary. Up to this point I have not found any source for a direct replacement on the motor. There are a few similar looking ones out there for sale, but without a cross-reference chart there is no way to know for certain they will fit and function properly.
The way the cabinets around the furnace were installed makes any changes to them very difficult. The newer furnaces are slightly smaller, so perhaps one will work and allow for ducting to be connected. I'll see.
Thanks for your suggestions. I will keep them in mind as things progress.
KD9GRB
Offline sledhead
« Reply #20 on: November 05, 2017, 04:46:37 AM »
you should get a saw like this https://www.homedepot.com/p/RIDGID-JobMax-4-Amp-Multi-Tool-with-Tool-Free-Head-R28602/206824272
it makes it easy to ADJUST ! things to the new systems .
I have redone a lot of stuff on the dated featherlite as some of the systems that were state of the art in 2000 are not made today and I have a saw like that and it makes work easy and precise when redoing things
dave
dave , karen
Offline lostagain
  • MC5C
« Reply #21 on: November 05, 2017, 06:45:21 AM »
Great suggestion from Sled Dave: the Multi Tool is the best invention since the hammer...
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740
Offline richard5933
« Reply #22 on: November 06, 2017, 12:50:08 PM »
Let the work begin. I was able to remove the floor of the cabinet above the furnace which gave me enough access to remove it.
1974 GMC P8M4108A-125 (Current bus)
1964 GM PD4106-2412 (totalled Sept 2017)
KD9GRB
KD9GRB
Offline Oonrahnjay
« Reply #23 on: November 06, 2017, 12:56:34 PM »
    Nice!  Good luck with what you find.
Offline richard5933
« Reply #24 on: November 06, 2017, 01:51:00 PM »
The inside of the furnace really looks like it's hardly been used. The paint on the heat exchange unit is fully intact, and the rest of the unit is in great shape. The only thing that I can see wrong at this point is the very stiff blower motor.
I was planning to attempt a rebuild on the motor, but on a whim I called Suburban. They had a current part number for the motor, and I was able to order one from a parts supplier. It should be here before the weekend.
If all goes well, I hope to get the furnace into my shop and do the motor swap this weekend. I'll try and get some photos as things progress.
KD9GRB
Offline chessie4905
« Reply #25 on: November 06, 2017, 05:24:27 PM »
Off subject, but does your coach have a u-line icemaker?
Offline lvmci
« Reply #26 on: November 06, 2017, 09:56:11 PM »
Hi Richard, do you have a suburban phone number? Tom lvmci...
MCI 102C3 8V92, Allison HT740
Offline richard5933
« Reply #27 on: November 07, 2017, 02:27:15 AM »
423-775-2131
This is the number for the parent company, Airxcel. The phone answering system didn't seem to have an option for consumers looking for parts and even said that they don't sell parts to consumers, but I pushed enough buttons to get a real person who was able to look up the part number for me. Once I had the number the part was only a Google search away.
KD9GRB
Offline buswarrior
  • '75 MC8 8V71 HT740
« Reply #28 on: November 07, 2017, 02:31:29 AM »
Well done on the tenacity!
When calling vendors, getting past the gatekeepers to someone inside who "just helps you" is the key.
Offline richard5933
« Reply #29 on: November 08, 2017, 01:43:31 PM »
This is what an unused 43-year-old heat exchange unit looks like. It's also why I'm making the effort to salvage the furnace.
Also a photo of the burner. Some surface rust, but no real sign of use or corrosion.
The only thing that I have to figure out is how to install a metal crossover tube as would have been done in the recall. This one still has the original rubber tube, and while it's still flexible and soft I figured it would be a good idea to swap out for metal. Apparently the recall part is NLA. I've got a length of 3" muffler pipe and just need to figure out a way to gasket the ends. Right now I'm thinking of using the original rubber tube as the gasket by cutting off 1/2" rings. The muffler pipe is a tight fit over the rubber.
Motor should be here tomorrow, and then I'll put things back together.
KD9GRB
KD9GRB
