Author Topic: Need cruise control switch  (Read 1187 times)
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
« on: November 06, 2017, 09:54:18 PM »
So I've found and identified all the wires associated with the cruise control. I've labeled them also. I still need the resume/set switch. I know it's a bit special so I had called and spoken to San Caylor about it three weeks ago and he said he'd call me back....well, I turned gray while I was waiting, so if anyone knows where I can get the paddle cruise set/resume accel switch, I'd be so grateful. My wife is tiring of holding the throttle down for hours on end.
Offline chessie4905
  • MCI-9 & MCI-102
    • Fresh Day Music
Re: Need cruise control switch
« Reply #2 on: November 07, 2017, 01:38:31 PM »
Can I even use those with my setup? I though the bus cruise switch had to be something special? I know the on off switch is normal but the resume/accel/set switch I thought was something unique on a DDEC II system?
Offline chessie4905
« Reply #3 on: November 07, 2017, 03:09:12 PM »
Didn't know what you had for system. So this probably won't do you any good. There is also King Cruise out there.
Here's some info from past post.
http://www.busconversions.com/bbs/index.php?topic=2575.0
They would most likely work....they apply intermittent connection when activating cruise/ coast/accel/decel. You'll need wiring diagrams to get it to work. Most cruise units activate with momentary application of desired button. Of course power to unit is  on/off
« Last Edit: November 07, 2017, 03:35:32 PM by chessie4905 »
Offline blue_goose
« Reply #4 on: November 07, 2017, 11:05:11 PM »
There is nothing special, The on and off is just a standard switch.  The Cruse and resume are just momentary on when pushed.
Jack
Data used in this document is made from 100% recycled electrons and magnetic particles. No electrons were harmed in the creation of this document.
Offline Oonrahnjay
« Reply #5 on: November 08, 2017, 04:33:10 AM »
  There is nothing special, The on and off is just a standard switch.  The Cruse and resume are just momentary on when pushed.  Jack
      When they're pushed, is the signal a pos or a ground?  Is the signal standard across types of buses/cruise control designs??  Thanks,  BH
Offline richard5933
« Reply #6 on: November 08, 2017, 04:57:58 AM »
...so if anyone knows where I can get the paddle cruise set/resume accel switch, I'd be so grateful. My wife is tiring of holding the throttle down for hours on end.
Are you looking for the set/resume switch that surface mounts to the dash or one which is on the end of a stalk (like on the turn signal stalk)?
1974 GMC P8M4108a-125 (Current Bus)
KD9GRB
« Reply #7 on: November 08, 2017, 05:39:50 AM »
Scott,I can send the old one from my D it is different from yours mine has 6 terminals and is a rocker switch not a paddle type it controlled the fast idle also have you called MCI ?
Offline blue_goose
« Reply #8 on: November 08, 2017, 06:00:45 AM »
You don't send anything but ground to the ECM
Jack
« Reply #9 on: November 08, 2017, 06:16:39 AM »
He is probably looking for the OEM switch to keep his dash original, you can make a dash look junky in hurry by adding switches.
I just replaced all my panels and switches at a cost on the D to keep the OEM look YMMD
« Last Edit: November 08, 2017, 06:18:50 AM by luvrbus »
Online lostagain
  • MC5C
« Reply #10 on: November 08, 2017, 07:11:13 AM »
My first call would've been to MCI. They are not always expensive. And some times, it is worth a little more to get the correct part.
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #11 on: November 08, 2017, 01:02:52 PM »
Ok yes I'm looking for the MCI switch. I'll call them and see what they say. Thanks. Correct on the grounds to the ECM
