. . . took me an hour and two cans of engine degreaser to clean out the trucks intercooler fins and radiator fins from all the oil residue.
You guys would like these new vehicles. You don't need a crank to get them started anymore.lol
Well, with the Series Land Rovers, they have a hand crank clipped behind the front seats to turn the engine in case the battery is low. How many "new" vehicles can say that? You also can remove the transmission and clutch from inside the vehicle if the weather is inclement. The list of advantages goes on and on. There is even one part on Series Land Rovers that is also used on Eagle Coaches. If anyone out there knows the answer to that, I will give you one.
Why would running against the governor make an engine leak more? Compared to say 1800 rpm. Is it a matter of crankcase pressure, or something else?JC
Okay, you can give me batteries, radiators, belts, filters, the entire engine, wiring, transmission, and so on. Or you can be more specific. And if the Series Land Rover engine can be started with a hand crank, it can't have much horsepower; like less than 20?
Walter, we are forum friends and I intend to stay that way with you, but I just can’t be on the same page when it comes to rovers vs land cruisers. Land Cruisers have a proven reliability record. Land Rovers have the opposite. They are equally capable off road without a doubt, but they are just not quite up to the reliability standard I hope for.Sent from my iPhone using Tapatalk Pro
I never worked on a Land Rover but have Eagle so tell me a switch ?
I always wanted a Land Rover from the 60 or 70's I owned a 2000 Range Rover I bought new it was a piece of junk with the Buick engine
