Author Topic: Oil pan gasket?  (Read 5091 times)
Offline buswarrior
Re: Oil pan gasket?
« Reply #15 on: March 01, 2018, 05:23:04 PM »
Jason, for the love of GAWD, please find the torque specs for this piece in your engine manual.
after you crack or warp it based on casual typing...
Some stuff, you gotta confirm in the religious writings.
It's your salvation?
Re: Oil pan gasket?
« Reply #16 on: March 01, 2018, 05:29:00 PM »
They are 18 to 22 ft lbs Jason it's in the lube section (4) of your manual  ;D you lucky dog you only have 8 to tighten
Offline jmblake
  • Jason & Martha Blake
    • Creative Custom Cabinetry
Re: Oil pan gasket?
« Reply #17 on: March 01, 2018, 05:34:51 PM »
Thanks Cliff! Is there any particular pattern for tightening them?
BW, I would have definitely looked it up before moving on ;D just figured I would ask first ;D
Thanks guys
Re: Oil pan gasket?
« Reply #18 on: March 01, 2018, 05:42:08 PM »
Yes follow the X pattern beginning in the center of the pan
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
Re: Oil pan gasket?
« Reply #19 on: March 02, 2018, 04:08:55 AM »
If only I could stop my oil leaks with a simple oil pan gasket change....my 8v92 is now leaking from literally every side of the block from every hose, orifice, gasket, and groove.
Offline chessie4905
Re: Oil pan gasket?
« Reply #20 on: March 02, 2018, 04:38:11 AM »
Thoroughly clean engine, then look for leaks shortly after. The air movement in engine compartment makes everything look like it's leaking. You could install a Walker air Sep. They are used a lot on boats to keep engine clean.
http://www.walkerairsep.com
Re: Oil pan gasket?
« Reply #21 on: March 02, 2018, 04:46:57 AM »
Probably all the oil is coming from the top around the blower area unless the re builder decided  RTV was the way to go on the gaskets
Offline eagle19952
Re: Oil pan gasket?
« Reply #22 on: March 02, 2018, 12:23:48 PM »
Could have originally been a marine cast block.
I think DD had a buy one get one free sale back when the Navy stopped using them, they were gov't spec'd to ooze oil in salt atmosphere...too minimize corrosion and reduce painting costs.... :)
Offline jmblake
Re: Oil pan gasket?
« Reply #23 on: March 02, 2018, 05:47:32 PM »
Scott, Do like Cliff suggested and clean it up and see where it's coming from, those fans just spread it around and make a little leak look like something major. I hate leaks and try to keep things clean, my old 71 didn't leak much and I hope to get the 50 series the same ;D
Jason
