Author Topic: Two Alternators on 8v71?  (Read 6450 times)
Offline PP
  • Will & Wife
    • Bookworm
Re: Two Alternators on 8v71?
« Reply #15 on: March 06, 2018, 08:32:10 AM »
Can anyone with 2 alt's share some pics of placement /mounting please?  :)
I will see if I can make this picture small enough to load.  ???
Will
Offline Utahclaimjumper
« Reply #16 on: March 06, 2018, 09:14:54 AM »
  Detroit 8V71s are enimic enough with out loading them down with questionable equipment that can be dealt with in other ways.>>>Dan
Utclmjmpr  (rufcmpn)
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Offline PP
  • Will & Wife
    • Bookworm
« Reply #17 on: March 06, 2018, 10:22:25 AM »
Yes, remember this setup is on an 892. I also wasn't aware that Alternators run in either direction. Good to know.
Offline PP
  • Will & Wife
    • Bookworm
« Reply #18 on: March 06, 2018, 10:24:28 AM »
I can't reach the back of my coach right now because its hanging out over a swamp so I shot this through the side door. It's really hard to post pics here. Everything I tried short of uploading a miniature file wouldn't work. ???
HTH Will
Offline PNWorBUST72
« Reply #19 on: March 06, 2018, 06:02:13 PM »
So are those sitting where the AC was and just running off those pulleys?
Are they 12v and a 24v?
1978 MCI-8 Crusader - First Conversion!
Jacksonville Florida
Offline PP
  • Will & Wife
    • Bookworm
« Reply #20 on: March 07, 2018, 09:09:07 AM »
The small one is 12V and connects directly to the house bank. The large is the 24V. Both are on pivot mounts with belts running directly off the main pulley on the front of the engine. If the water goes down in the next few days, I'll try to get a better picture. It's really a simple setup. This coach has never had over the road air, just up front defrosters because it was never a passenger bus. Went straight from Prevost factory to Marathon.
HTH Will
Offline PP
  • Will & Wife
    • Bookworm
« Reply #21 on: March 07, 2018, 01:37:55 PM »
Okay, the tide went out and the swamp went down so I was able to get behind the beast. Hope these help give you an idea of what you need or want to do.
Will
Offline Geoff
« Reply #22 on: March 07, 2018, 01:55:43 PM »
What is the cam pulley turning?
Geoff
'82 RTS AZ
Offline PP
  • Will & Wife
    • Bookworm
« Reply #23 on: March 07, 2018, 04:37:35 PM »
Power steering pump.
I should add, that's where most of the oil spotting you see is from, not the engine.
Will
