Author Topic: Bay dimensions  (Read 2499 times)
Offline Hi yo silver
Bay dimensions
« on: February 04, 2007, 08:27:41 PM »
The answer is probably somewhere in the archives, but I don't see it.  Will my 8 foot step ladder fit crossways in the bay of a 96" bus?  If it won't, I might as well give up and get rid of the unused ladder I've been hoarding for the last 5 years.  Thanks
Offline H3Jim
Re: Bay dimensions
« Reply #1 on: February 04, 2007, 08:33:12 PM »
YOu probably have les than 8 ft across.  I have a 102, and I have a little less than 8 ft myself.  It can still fit if you put it on its side, and diagonal across the bay.  Not very effcient use of space though.  I save all those things until I can actually try it.  The space etc sometimes surprises me, and other times it give me yet another "genius" rated idea when I see the items and the space together.
Jim Stewart
captain ron
Re: Bay dimensions
« Reply #2 on: February 04, 2007, 09:39:10 PM »
NO
Offline NCbob
  • "Foolish Pleasure" 35' MC5A
Re: Bay dimensions
« Reply #3 on: February 05, 2007, 01:30:29 AM »
Dollars to donuts says the ladder won't mind if you cut a foot off of it....just make sure you cut it off the bottom...... ;D
NCbob
True friends are difficult to find, hard to leave and impossible to forget.
Re: Bay dimensions
« Reply #4 on: February 05, 2007, 05:56:07 AM »
My 102" wide coach won't fit anything 8 feet long straight in the bays.
I found this out when I loaded 20 or 30 sheets of plywood in the bay.  The door wouldn't quite close all the way.  I had to drive the 5 miles home slowly with the bay door wide open.  I did take out the light bulb so it would be less likely to catch someone's attention.
Brian Elfert
Offline Runcutter
    • Runcutter.com
Re: Bay dimensions
« Reply #5 on: February 05, 2007, 07:01:37 AM »
Dennis, a question.  Is there a way you can fit it diagonally (either horizontal or vertical orientation)?  If it doesn't have to be parallel or at right angle to the coach, you gain some extra length, and you may not have to skew it much to gain what you need.  The middle bedroom in our 4107 is a little short for my taste, so I'm working on a concept to place the bed at a slight angle - to gain some extra legroom (don't plan to use it while moving).
Arthur
Offline Ed Hackenbruch
Re: Bay dimensions
« Reply #6 on: February 05, 2007, 09:23:03 PM »
I have a 12 ft. ladder in the bay of my 5A.....of course it is a telescoping ladder that is only 29 or 30 inches tall when collapsed. ;D
Re: Bay dimensions
« Reply #7 on: February 07, 2007, 11:56:03 AM »
Thanks, Guys.  Arthur, I think I'll probably just keep it in the basement for Marilyn to use when I'm at home, and if I need to carry a ladder, just get a collapsible job...for her to use on the road.  That will work, right guys??
Re: Bay dimensions
« Reply #8 on: February 07, 2007, 11:58:48 AM »
Hey, Brian.  My reaction to you driving with the bay door open is the same thing the cowboy said when the Indian shot a flaming arrow at his wagon.  "Can he DO that?" Ha!
Re: Bay dimensions
« Reply #9 on: February 07, 2007, 01:15:40 PM »
I bought a folding ladder at one of the box stores, aluminum,folding and extends to reach just the top of the side of the coach. It has worked great and does not take up too much space in one of my bays.
Happy Trails,
Offline Beatenbo
  • 1993 MCI 102 C3 Cat Power
    • The Beatenbos
Re: Bay dimensions
« Reply #10 on: February 07, 2007, 07:30:21 PM »
Gettin' old. The only way I want to see the top of my bus is from a 2 story window. Dennis have you opened your wallet yet?
