I have learned a lesson but for now, I guess life goes on and if something happens, that is when I get it fixed. Kevin in Arizona said, "nothing money can't handle."
If you can get under the bus, always easier to pull the drive shaft, then pulling the axle half shafts. Then you don't have to worry about loosing lube. Good Luck, TomC
