InsuranceEven if they are going to transport it to you, you should be sure to have it insured before it is moved. Once the bus is yours, then you are the one with a potential loss if something should go wrong along the way.When we bought our first bus there was over a month in time between buying it and me going to pick it up and take it home. I called and arranged insurance immediately, even for the time before I physically took possession of it.I did this to protect against any damage to the bus. But more importantly I did this to provide liability in the event that someone was injured, even with the bus sitting still. Things happen with no way to predict or prevent them. Even more so when the bus is not in your possession. If you are the owner, then you're on the hook if there are any problems.
...If they deliver the bus the seller is responsible for the insurance till it is delivered not Jim
Technically you may be correct, but if there is an 'incident' or if someone is injured the attorneys are going after anyone and everyone involved. I've also seen purchase contracts from dealers that specifically mention they have no liability or coverage on the vehicle once the vehicle is sold (before delivery). Easy enough to get ones @$$ covered, especially if he has a policy like you've mentioned.
My understanding of the 30 day rule is current coverage is applied to new vehicle. In the case of the new vehicle being one that has no existing coverage, that rules likely does not apply. For example, you may have liability only coverage on cars, go out and buy a new car, and expect it to have full coverage. No go joe. The current coverage but no automatic increases to coverage just cause you bought a new car.
Once it gets here the first thing will be to remove all the seats and that should be finished in a couple of hours.Jim
