Author Topic: Using Original Windows  (Read 7187 times)
Offline daddysgirl
  • Second build on the third bus...Yes, it takes a nut!
  • Daddy's Girl Jr.
Re: Using Original Windows
« Reply #15 on: January 21, 2021, 08:19:36 AM »
I have the bus windows, but four of them slide, and the rest pop up.
I accidentally hit a rear window with a crowbar, so I'll need to replace it when I decide how the interior layout will be re-arranged.
Andrea   Richmond, VA
Offline peterbylt
« Reply #16 on: January 21, 2021, 08:26:04 AM »
We covered 5 of the windows and retained 7 of the original windows and replaced the two front windows with Motion Windows, they mounted right in without any modifications.
The tint on them matched almost exactly the tint on the original windows, they do not leak, no wind noise at 70 mph, we are very happy with them and use them all the time, the built in screens are nice.
We plan on replacing the two rear windows in the bedroom with Motion windows.
One of the benefits we originally had not thought of is the ability to have open windows while we are driving.
In my opinion although relatively expensive well worth the price.
Peter
Tampa Fl,
1989 MCI 96A3, 8V92TA
Offline daddysgirl
  • Daddy's Girl Jr.
« Reply #17 on: January 21, 2021, 08:33:00 AM »
Where did you get those? I would like to find a couple of drop-in replacements.
Peter
Andrea   Richmond, VA
Offline peterbylt
« Reply #18 on: January 21, 2021, 09:14:20 AM »
daddysgirl,
We got these from Peninsular Glass, Motion Windows.
https://www.rvwindows.com/
Peter
Tampa Fl,
Offline Jim Blackwood
« Reply #19 on: January 21, 2021, 11:25:31 AM »
Do you have an email address for them? They don't make contacting them easy.
Offline chessie4905
« Reply #20 on: January 21, 2021, 11:58:16 AM »
my 4905 has several motion windows except the one by the driver. I got one for it and installed last year. I think it may have been obe of the last ones available, Ive heard that they arent available for GMC's anymore. expensive, very nicely made, super weatherstrip supplied with it, and nice wood shipping crate to protect it.
Offline 6805eagleguy
  • Have you ever seen a sad person rolling coal?
« Reply #21 on: January 21, 2021, 07:35:13 PM »
We bit the bullet and got custom windows for our bus, from motion. 7week lead time for custom windows didn’t seem bad , price was plenty but they are nice windows
Jim for custom windows they have a build sheet on their website not sure if they still have bus windows
1968 Eagle model 05
« Reply #22 on: January 22, 2021, 02:02:14 AM »
Finally got their email app to work and heard back from them right away. Side windows for the DL are $525 and $685, single and DP respectively. Not cheap but within the budget if I did 2 windows in the front and 2 in the bedroom. That will likely happen but maybe not until after the bus hits the road. Hard to say what the shipping will be.
Offline chessie4905
« Reply #23 on: January 22, 2021, 04:16:11 AM »
Yeah, not cheap, but nice. I think my driver's window was around $400.
« Reply #24 on: January 23, 2021, 07:17:16 AM »
I wanted to use the original windows on my transit bus (AMGeneral) to save money. But they were rattly, leaky and could hear out side through the gaps (because they were emergency opening windows-nice when working on the bus though). I decided to go with Peninsula windows. With the shape, only single pane windows were available and had to be mounted to the outside. WELL-the bus now is so tight I have to keep the bathroom roof vent open all the time. Otherwise when I close the outside door, my ears pop.
Offline chessie4905
« Reply #25 on: January 23, 2021, 11:48:08 AM »
Cars and trucks have out of site flap vents to avoid this. The issue popped up for the first times wives angrily slammed car doors. Hmmm maybe thats why married mens hearing goes bad as they age.😂
Offline richard5933
« Reply #26 on: January 23, 2021, 12:05:21 PM »
I've got a similar problem on my coach - if the nose vent isn't cracked open there's a sudden pressure jump inside if the door is closed quickly.
When we've got the OTR a/c or heat running we have the opposite problem - the HVAC system brings in a small amount of fresh air as it runs, and that pressurizes the interior of the coach. While everything is turned off we can usually just leave the door in the closed position as we load, but if the OTR HVAC system is running the door will blow itself open every time we try to close it unless it's latched.
GM builds a tight bus. For sure.
Offline chessie4905
« Reply #27 on: January 23, 2021, 04:07:31 PM »
I always keep bathroom vent open an inch. Moisture is not your friend.
Offline dtcerrato
« Reply #28 on: January 23, 2021, 04:35:42 PM »
Especially if it's part of a fart. Couldn't resist...
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline Jcparmley
« Reply #29 on: January 24, 2021, 07:40:46 PM »
Totally agree!!!  :)
1989 MCI 102c3 6v92TA Mechanical
