Author Topic: Dropped the oil pan, now what? Trying to fix oil leaks.  (Read 1256 times)
Offline neoneddy
    • Youtube Build Log
« on: May 01, 2020, 07:52:53 AM »
I'm tracking down the oil leaks on my 6v92 here.  Every darn bolt had a drop of oil on it it seemed. When I turn just right I'd leave a trail of oil.  I figured I had a leak in the side of the pan gasket.  When I took it off the gasket was in tack and appeared to be in good shape.  I couldn't see any part of it that was wet with oil.
Now on to what I did find and need help with.
I found all the bolts had lock wasters on them.  I thought copper washers was the norm
I found a few bolt holes that where stripped out. (see attached.)
I noticed a few of the other where stripped but had a longer bolt put in and it was re-drilled and tapped I assume.  On my trans bell housing there are a mix of 5/8 and 1/2 inch bolt heads going around it.  I'm assuming the 5/8 ones used to be 1/2 and where drilled and tapped.  I've had some recommendations on doing helicoils, or should I skip it and just have a few 5/8 oil pan bolts?
Other than that, the bottom end looks clean, oil pickup looks good, nothing on the oil drain plug, nothing in the oil pan.  I'm happy.  Some have also suggested looking at the rod bearings, I'm a little nervous I won't torque it back to spec properly and ruin something.
Raising hell in Elk River, MN
1982 MCI MC9
6V92 / 4 Speed Auto (HT740) Video Build Log - Bus Conversion & RV Solar company we now started thanks to our Bus
Re: Dropped the oil pan, now what? Trying to fix oil leaks.
« Reply #1 on: May 01, 2020, 08:12:22 AM »
They use no copper washer just lock washers and have they 2 different lengths of bolts the side bolts really don't make a difference in being longer,the end bolts need to be the right length,replace the pan gasket by the engine serial number because the engine could have a cork gasket or a paper gasket and do not over torque the pan bolts and they don't leak
Offline chessie4905
« Reply #2 on: May 01, 2020, 04:11:53 PM »
Remember, oil leaks go mostly downward except for fan blowing it around. Best to start with a thorough cleaning with a pressure washer, then take short drives to help locate sources. The more worn out the piston rings, blower seals etc, the more it'll leak from crankcase pressure.
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
« Reply #3 on: May 01, 2020, 11:50:36 PM »
As someone who has just spent almost two months replacing his engine, take cliffs advice and be sure you’re aware of what oil pan gasket you have. It’s important. Thankfully with a completely rebuilt 8v92 in my coach, I don’t currently leak a drop. We will see how long that lasts.
