Author Topic: New window air conditioner that might be hackable into a quasi mini split  (Read 5164 times)
Offline Jim Blackwood
By that metric, 3-4 tons should be adequate for any eventuality. That means the two rack air units and maybe the dash air if needed. That's a rated 4 tons and possible 4.5 tons based on the TXV's. Which means a pair of 2 ton Copeland scroll compressors should handle it. Depending on seer, around 15-20A each. Wonder if they make them in 110v versions? I guess they must because, window units.
Offline ccbmster
Sorry it took so long to post the requested pictures.
This is a 110v, 12k btu, inverter technology, 16 seer, heat pump, Air Con mini split.  I bought it 3 years ago for $450 when it was an unknown brand and it has performed flawlessly.
Recently in OK the temp was over a hundred degrees and I couldn't push enough air from the back of the bus to the front through two doorways to cool the front.  So I am in the process of tearing everything out of the road ac bay just behind the front wheels to put a second mini-split there with the air handler just below my cabinets on a wall where the second window behind the driver was.
This Air Con unit is now well over $800.00, so I have a Daizuki 110v, 12K btu, inverter technology, 20 seer, heat pump unit on the way instead.  Should be here in the next couple of days.
86 MCI 102A3  Travel MI, IN, OH, VA, KY, GA, FL, and OK with most time spent in GA and FL 6V92 with Allison 740 Automatic
Easy to see the attraction when you can buy a Garrison 18K from walmart for $318, about $350 delivered. 220v though so there's that, but also seer 20.8 which is good. A comparable window unit costs as much or more. But why wouldn't you also be able to combine that with the OTR air? I think I can see a path starting to take shape here.
Offline ccbmster
I don't see where you can by a mini-split of any kind for that from Walmart.  Are you sure you are not looking at a price on just the air handler?
Even on Ebay the cheapest mini-split is a little under $500 and that is not a heat pump unit.
As for the over the road air, mine needed freon and I decided it was not worth it to do that and keep up the maintenance long term when a heat pump mini-split is as cheap as they are and can be used both over the road and when parked.
I just did a search for air conditioner on the walmart site and clicked on the mini-split icon. 2 or 3 pages came up.
Offline ccbmster
Cheapest I see is the Garrison 9K btu for $446.00
