In my 1981 MC-9 with 8v92ta, the oil pressure gauge in the dash stays at about 4 psi, engine running or not. I disconnected the wire at the sending unit at the engine, and the oil pressure gauge reads below 0 psi. I then touched that wire to the frame of the bus, and the gauge reads max pressure. The dashboard and gauges look all original to me. Is my gauge acting correctly?
There is a manual gauge mounted next to the sending unit that reads what I expect, so there shouldn't be any blockage.
I think I need a new sending unit, does that sound correct? Can I get one locally or do I need to call Luke?
Thanks.
