Author Topic: Balancing 240 volt generator with step down transformer  (Read 5152 times)
Offline jap42
  • Jr. Member
Re: Balancing 240 volt generator with step down transformer
« Reply #15 on: July 18, 2020, 02:00:50 PM »
Center taps did not occur to me. That would make a lot more sense for 120 to 240.
I would still worry about the wave form stepping down. Transformers are defiantly not my strong area, I understand the function but not the process. 120V applicances use 120V Half Phase. So there is a period of voltage and then a period of no voltage. And the neutral never has voltage. If you stepped 240 down to 120 wouldn't you have voltage present on both sides? Im sure a toaster would not care but would that affect electronics? Not to mention a short to ground on a bonded panel?
However for the purpose of balancing the load could you do equal windings (240V to 240V) with a center tap on the secondary. Wouldn't that evenly distribute the load on the primary side Even if you only used half of the secondary?
Offline Jim Blackwood
« Reply #16 on: July 19, 2020, 05:26:00 AM »
120v and 240v are both full sine wave, the difference is that the two legs of 240v are 180 degrees out of phase with the same zero reference. so when you reference either leg to ground you get 120v as the peak of the sine wave going either positive or negative. For 240v you are measuring across both legs so while one leg is peaking in the positive direction the other is peaking in the negative direction giving a total of 240 across both but 120 to the zero reference which is ground. Then the cycle reverses and the one that was positive goes negative, etc, and you get the same 240v. It's a sine wave because that's what an electrical AC generator produces, and what transformers are most efficient running. But there is no gap in voltage, just the zero crossover point. Power factor is an average .707 of peak voltage.
HTH
