Author Topic: Boon docking and off pavement with a 45' coach.  (Read 31105 times)
Offline someguy
  • In the planning stages of converting an E/J4500.
Re: Boon docking and off pavement with a 45' coach.
« Reply #75 on: August 16, 2020, 12:35:27 PM »
The wise busnut will design their coach to be self contained, and any facility to dump to ground will be kept innocent and hidden.
The authorities are not as hindered as they were when the hippies were loose in the wild... the clamp down on this free spirited behaviour will continue...
Be happy, plan to tank all your waste.
I agree.   I'll plumb in a grey water diverter in case I can dump that directly to ground.  Simplifies plumbing greatly and only 1 waste tank instead of 2.
How big should my fresh and waste tanks be ?   I do a lot of no hookup camping and will be doing a lot of boondocking.
How does one stop smells from coming up from the tanks into the coach when driving on rough roads due to the water in the traps sloshing out ?
« Reply #76 on: August 16, 2020, 01:13:01 PM »
They have waterless P traps for RV"s my Country Coach has the weird looking things
Offline someguy
« Reply #77 on: August 16, 2020, 01:21:40 PM »
Thanks !  I've never heard of them.
Where do bus conversions run the plumbing vent stack ?  To the roof ?
Offline richard5933
« Reply #78 on: August 16, 2020, 02:16:42 PM »
Here's what the waterless P trap looks like, as well as the old one it replaced. The change freed up lots of usable space under the kitchen sink. Apologies for the rotated photo.
Most modern conversions will vent plumbing similarly to residential plumbing with a roof-top vent. But, it's not mandatory.
The third photo is the back of our water/waste tanks. The two 1/2" lines running out the top and down through the bay floor are all the venting we have. Surprisingly, we've never had an issue with water flow or waste tank venting odors.
Offline someguy
« Reply #79 on: August 16, 2020, 02:19:43 PM »
Thanks for sharing that !
Where did you get those tanks ?  I like how clean that setup is.
Offline richard5933
« Reply #80 on: August 16, 2020, 02:22:59 PM »
The tanks were made by Custom Coach in 1974 for this coach. They made their own - the basic construction is 3/8 poly sheeting heat welded together. There are partial baffles inside to give the sides strength and prevent them from pushing out. The fittings are bronze flanges simply screwed to the 3/8" material with machine screws using soft rubber gaskets. Only thing I've done is change the gaskets and repair one top seam that looked like it was never properly welded at the initial assembly.
Offline someguy
Offline Jim Blackwood
« Reply #82 on: August 16, 2020, 02:32:37 PM »
Asking about tank vents here is opening a can of worms, but away we go again...
First off, the best way to control tank odor is to introduce oxygen to the tank. Do that and you get aerobic decomposition. Don't and you get anaerobic decomposition which is just stinky and produces heavier than air aromatic gasses. Those stack up in the tank and tank vents so that when the toilet gate is opened the weight of the gases in the vent line, acting as a stand pipe, forces the gases in the tank back up and out of the toilet. It can get worse when moving due to the pressure differential between inside and outside.
With that knowledge it is a relatively simple task to design a system that will solve the problem but it may not be possible to have a passive solution that works under all conditions.
Offline sledhead
« Reply #83 on: August 16, 2020, 02:48:23 PM »
I like your tank level monitoring system
I can see the levels , wish mine were that clear
if I use the grey tank rinse sprayer I can sometimes see the level of the tank without using the tank monitoring system
fresh is easy to see but the black tank is black so no way
all my tank monitoring system work but it sure would be easy just to look at the tanks like yours
dave
dave , karen
Offline richard5933
« Reply #84 on: August 16, 2020, 03:10:14 PM »
This stuff ?
https://www.usplastic.com/catalog/item.aspx?itemid=41935
Looks the same - don't really know which acronym they used for mine. Before buying online, check locally. Most areas have at least one commercial plastics supply house, and they usually sell retail as well. Often then have a selection of inexpensive end cuts and such.
Thanks. I like it too. We always run off the tank using the electric pump, never directly from city water. Both tanks are identical in capacity. Since we never fill the fresh all the way to the top, there is no way we'll ever accidentally overfill the waste tank, unless lots of canned beverages are being flushed, of course.
Offline someguy
« Reply #85 on: August 16, 2020, 04:51:01 PM »
1 sheet of that material could make a tank approximately 19 x19 x 48, not including baffles.  Which is approximately 75 gallons.
The material description says it is very weldable.
Richard: could you give us more info on your tanks ?
Offline richard5933
« Reply #86 on: August 16, 2020, 05:15:38 PM »
Not much excitement to my tanks, but I'll try.
They are each approx. 20W x 43L x 25H. My calculations show roughly a 90-gallon usable capacity.
They are made of poly material 3/8" thick, each with 3 internal baffles. The baffles are only about 20" tall in the fresh water tank, a little less in the waste tank, and alternate positions in the tank (lower/higher/lower). There are about 4-5 inches below each baffle to allow movement of the waste in the waste tank, less so in the freshwater tank.
The connections are made with bronze flanges screwed to the poly with machine screws. Rubber gaskets make the seal. I redid the gaskets recently using silicone gasket material and a very thin coating of silicone gasket making compound (food safe for the freshwater tank).
I've attached a few more photos that might show the connections to the tanks better. Since these were taken, I've redone the gaskets on the flanges for the fresh water outlet and the waste water valve connection.
If you have specific questions I'd be happy to answer.
Offline someguy
« Reply #87 on: August 16, 2020, 05:42:03 PM »
Thank you.
Offline Busted Knuckle
« Reply #88 on: September 12, 2020, 09:18:02 AM »
"Standard truck axle" means something different to you than it does to someone looking to swap one... they are upside down, and not every axle can be rolled over.
Put a regular truck axle under your bus, and it will have multiple speeds in reverse...
The guys who were trying to get different gears back a bunch of years ago, to match their drivetrain swaps, had to do a lot of research and find a bemused representative at the axle manufacturers to give them a hand.
A stock locker would be nice.
Happy coaching!
Buswarrior
BTDT! Not by putting a regular truck rear end either. But we replaced the third member in our S217 once and don't ask me how but we managed to put it in backwards! I don't know if it was because it was a Kassboro rear end or what I have NEVER and I mean NEVER seen a rear differential go in but one way before (or maybe I was just lucky and always got it in the right way by accident before)
Anyway it was a Saturday afternoon when my dad, uncle an I finished putting it in and dad told me that he and Robert would finish it up an I should go up the the house and get cleaned up for my run the coach had to go out on in about 3 hrs!
I'd no sooner got ready to step in the shower when my phone rang, I looked an it was dad so I answered it. Dad said "If you haven't got in the shower yet you might want to wait and come back down here. Robert went to back it out of the shop and it's got 6 reverse gears and one forward gear!"
So I put my dirty clothes back on and back to the shop I went, I was sure Setra had somehow screwed up and sold me the wrong rear end. I was furious! As dad, Robert an I were discussing it I went over to one we'd pulled out and examined it. I looked it over really hard and told them ya know "It just might be possible it's upside down, don't ask me how but it looks like it's possible!"
They both looked at me like I had 3 eyes and said "WHAT? How is that even POSSIBLE!"
I showed them how it was the same all the way around with no differences in the bolt pattern or shape or anything different at all except there was a small "hump" for the ring gear off center in the rear of it.
So of into the pit I went and sure enough the hump was on the opposite side than it had been before we'd pulled the original one out, I was lucky to remember that from all the times I'd looked at it while servicing it before.
So I asked Robert if he minded going home and getting cleaned up to drive it tonight while dad and I flip it. Wasn't NO WAY I was ASKING dad to drive that night as he an mom had plans that night! (or should I say mom had plans) It was their 48th wedding anniversary!
Robert agreed and took off dad an I went straight to work pulling the axles pulling the rear end and breaking the "come along" we were using to suspend it in the air from the bus since the ground was 6 feet below in the pit! I quickly grabbed the oil barrel we kept in the pit for oil changes and slid it over under the rear end and released the come along, BOOM the rear end slammed down on the barrel and smashed the barrel on one side, but it stayed up!
We searched for another come along and I told dad I'd thrown the other one away (we were hoping between the 2 bad ones we could make one that would work long enough to do the job)
Dad jumped in the truck and went an got another come along while I stayed and got things ready to shove it all back together as soon as he got back. Our bus cleaner had showed up and was helping me get ready when I reached down and grabbed the rear end picked it up and flipped it over and put it back down (and I'm pretty sure that's when I damaged my back too).
Chuckie's eyes were the size of golf balls and he said "Wow remind me if I ever piss you off to keep running! How much does that weigh any way?" Well I'd just paid for shipping so I looked on the shipping tag 398 #'s! I didn't say anything I just showed him the tag. (but 20+/- of that was the heavy pallet they used too!)
Any way dad got back and we went straight to work and got it back in just in time. I backed it out of the shop and Chuckie did a walk through just as Robert pulled back up.
Robert asked "Did ya test drive it, to make sure it's OK?"
I told him "Yup sure did backed it out 75' turned and pulled up right here 25' so it's been tested 100' and it only has one reverse now, so I'm sure yer good to go!"
So yes I know at least with a Kassboro rear end it can be done!
Also no they are not regular truck rear ends the housing are different and have built in supports for the coach so they don't break and fold in half. Also the whole thing is heavier duty than the standard road tractor so one out of a "heavy haul" truck might be the same, but I have BTDT to with trying to use a junkyard differential in an MCI and it didn't worK!
OH BTW there is a certain Eagle in NV that has a heavy duty dump truck rear end in it was well as air ride, custom tag axle and a pretty yellow motor that was built by the late Sonnie Gray!
OH and Brian your 43' coach is much better designed for rough/off road use as they were mainly designed for use in South America where the roads are not as good as the US!
Someguy you do as you wish but I wouldn't take a E or J model very far off a public roadway and I sure wouldn't take one on the logging roads around here!
Offline TobyU
« Reply #89 on: December 25, 2020, 04:49:39 PM »
I think they made a big deal out of nothing. A good driver could have maneuvered out of there without the chit-chat. There was a camera at the fifth-wheel, she was not needed. I doubt the driver had tractor-trailer experience.
It was really tight but doable. He was favoring the right side too much IMO. About 4-5 feet of pavement on the left. I would have been over there more and at the last second turned fast watching and just missing the right gate. Might have needed a 3-4 inch back up but it looks doable.
