Author Topic: MCI MC5B air filter retrofit  (Read 4378 times)
Offline Jsrcaptain
  • Jr. Member
Re: MCI MC5B air filter retrofit
« Reply #15 on: November 14, 2020, 02:41:09 PM »
I have the one support with the two 7/16" holes. I think I need the other that has one 7/16th hole if I am reading this right. Does that look like the right one? I think it is an older style as it doesn't have 71 stamped on it.
1972 MCI MC5B, 8V71 NA
Baraboo, Wisconsin
« Reply #16 on: November 14, 2020, 03:07:36 PM »
Takes 3 per side here is a photo plus the air horns 1 is a 5 inch,1 is a 6 inch then you have the low profile with the rectangle opening
Offline Jsrcaptain
  • Jr. Member
« Reply #17 on: November 14, 2020, 04:37:48 PM »
I'm looking at a 1977 engine manual. It says the stabilizers are on #4 and #5 main bearing caps. Are they on all the caps now? You said three per side. So you need six? Sorry I'm a little slow. I really appreciate your help. Good information is hard to come by. The 6" intake looks kinda tall in your picture. I should measure the available height I have. Bigger is better with the intake I think.Is that a one piece unit with the flapper inside?
I'm in south central Wisconsin. If you aren't too far away I'd like to stop by some time.
Baraboo, Wisconsin
« Reply #18 on: November 14, 2020, 04:54:15 PM »
They are on all mains now ever since 1979,lol there 2 on each side not 3 sorry
Offline Jsrcaptain
  • Jr. Member
« Reply #19 on: November 14, 2020, 07:16:42 PM »
Thanks, I just watched a video showing the installation. It makes more sense now. If I don't have them on the engine now it looks like I will need longer bolts for the main bearing caps in order to install them. I'm gonna have to pull the oil pan and take a look. Maybe I'll get lucky.
Baraboo, Wisconsin
« Reply #20 on: November 15, 2020, 07:55:12 AM »
Good luck
