Author Topic: Demo questions  (Read 1734 times)
Offline benherman1
Demo questions
« on: November 14, 2020, 01:13:46 PM »
Hello,
I'm still tearing out the interior on my bus and have a couple questions after removing the drivers side air duct.
There are coolant lines running inside the duct. I assume for the defroster considering where they go. Is there any reason these were run here rather than in the space under the floor? I assume others have moved them there in the past? If so is there any particular way I ought to do it?
I have removed the outer steel panel above the duct that has the air gap between it and the next panel with the little wood strips in between. Is the next panel structural? I'd like to remove it to asses rust issues and upgrade the insulation.
1964 MC5A - 5289 - Bloomington IN
Offline Jsrcaptain
  • Jr. Member
Re: Demo questions
« Reply #1 on: November 14, 2020, 02:49:10 PM »
This might help.
1972 MCI MC5B, 8V71 NA
Baraboo, Wisconsin
Offline benherman1
Re: Demo questions
« Reply #2 on: November 14, 2020, 05:02:49 PM »
It looks like the panel in question is structural. Is it safe to remove and re-insulate then put it back with rivets of similar quality? Everywhere else I've pulled off panels the fiberglass is in pretty sad shape. I assume in the walls will be the same so I'd like to get inside if at all possible.
Offline Jsrcaptain
  • Jr. Member
Re: Demo questions
« Reply #3 on: November 14, 2020, 07:23:32 PM »
As you may have noticed, I have a 72 MCI MC5B. Other manufacturers may do it differently. It's my opinion that most of the strength is in the monocoque frame. Any additional strength is probably in the outer skin. I have an aviation mechanic background. These buses are built just like airplanes.
Baraboo, Wisconsin
Offline Jsrcaptain
  • Jr. Member
Re: Demo questions
« Reply #4 on: November 14, 2020, 07:26:17 PM »
My defroster lines are in the same place. I would leave them alone if they are in good shape. I'm planning on running my rewiring along the same chase.
Baraboo, Wisconsin
Offline benherman1
Re: Demo questions
« Reply #5 on: November 15, 2020, 07:08:03 AM »
So I shouldn't have any issues removing the interior panels then? I did notice the inner side's rivets were considerably smaller than the outer ones. The outer skin holding more weight would make sense.
I've already removed the chase. I can build up the wall to cover them but repair work later would be pretty unpleasant. the valves to turn it off in the back and front are frozen so I'll have to tear into it anyway.
