Author Topic: Where to mount propane tank?  (Read 11958 times)
Offline windtrader
Re: Where to mount propane tank?
« Reply #15 on: November 20, 2020, 09:47:22 AM »
Agree on cut hose causing the most havoc and it is pretty realistic to think upon impact the 5 gallon tanks secured with the flimsy hold downs letting loose, tank goes flying intact but the hose gets severed. In that case though, the tank probably is in the ditch somewhere so maybe the actual fire hazard from the cut hose really would not create increased fire in the bus.
Lately, this forum is starting to scare me. It's all FAKE busnut hysteria! Now back to regular bus news. LOL
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
« Reply #16 on: November 20, 2020, 11:13:45 AM »
I'm part way through a bus conversion and would like some advice on the placement of a propane tank on my '91 102C3.
If you are worried about propane, then why use it?
Perhaps this photo is an excellent reason why the major conversion companies (Liberty, Marathon, Royale, etc.) tend to produce all-electric coaches?
Yes, it was a propane fire.
« Reply #17 on: November 20, 2020, 11:44:12 AM »
Propane is only dangerous as a owner chooses to be damn look at the CNG buses, 18 wheelers,pickups and cars on the road today powered by CNG
Offline richard5933
« Reply #18 on: November 20, 2020, 11:45:42 AM »
Perhaps this photo is an excellent reason why the major conversion companies (Liberty, Marathon, Royale, etc.) produce all-electric coaches?
Just saying it was a propane fire doesn't tell us anything - what actually caused the fire? Was it a propane fire due to a faulty refrigerator? Did the regulator fail? Was the tank struck and damaged? Was this at all related to tank placement or failure?
Offline Jim Blackwood
« Reply #19 on: November 20, 2020, 12:16:57 PM »
I wholeheartedly agree Richard. Despite safeguards that can be used, proper routing, protection, and good installation practices are paramount. Some tanks may have an outlet valve that shuts off in the event of a catastrophic leak but one of the best practices is to size the lines no larger than they have to be to feed the device using the propane. And of course never plumb to the liquid side. The corrugated stainless flex pipes are a good choice for any place where relative motion can occur, whether from vibration, normal use and maintenance or collision.
« Reply #20 on: November 20, 2020, 01:46:01 PM »
If it was a propane fire the fridge wasn't the culprit the door is still intact, maybe a furnace fire those are usually caused by lint build up caused by the owner never cleaning it,and I don't about the big guys never using propane if the owner wants it,I know of a 2010 Liberty bought new with a propane cook top
Offline Dave5Cs
  • BCM Subscriber
« Reply #21 on: November 20, 2020, 02:23:41 PM »
Well RJ at least the Solar panel in that picture you put up is in good condition..... ;)
« Reply #22 on: November 20, 2020, 03:04:09 PM »
The location looks like where a battery fire would have stated
Offline windtrader
« Reply #23 on: November 20, 2020, 06:38:11 PM »
One thing for sure is the propane tank did not blow up. LOL
Don F
Fully converted
Bought 2017
« Reply #24 on: November 20, 2020, 07:39:44 PM »
They rarely do. Really, that's a TV thing, that explosion business.
Offline chessie4905
« Reply #25 on: November 21, 2020, 04:13:23 AM »
Yeah, like tires screeching on sand and dirt, and locomotive blowing up in Unstoppable.
Offline richard5933
« Reply #26 on: November 21, 2020, 04:55:38 AM »
Here's a class C motor home engulfed in flames. At about 2:20 you'll notice what appears to be a propane tank letting loose. Not really an explosion - more of a burst of propellant into the fire. My guess it wasn't the tank itself cutting loose, as much as a line or valve melting.
https://www.youtube.com/watch?v=3zSjZVlnKHg
« Reply #27 on: November 21, 2020, 08:44:13 AM »
Sounded like a pressure relief valve. Could have been an air tank or even the fuel tank. Was there any indication that the fire was caused by propane? I don't think there was anything salvageable at that point in the video and if the occupants hadn't already gotten away safely they weren't going to.
Offline richard5933
« Reply #28 on: November 21, 2020, 09:38:24 AM »
No indication what started the fire. If you listen to the guy talking he makes the comment "there goes my propane tank" at one point. I doubt the fire was caused by the propane tank, but who knows.
I was really trying to show that even in a fire like this the propane tank doesn't explode, per se.
Offline edvanland
« Reply #29 on: November 23, 2020, 08:02:40 AM »
I mounted ours in the middle bay. Put in 2 7 gal tanks, that way when one runs out just switch over to the other and go get the empty one filled. Don't have to move the bus.
ED
Ed Van
MCI 7
Cornville, AZ
