Author Topic: 1998 DL3 extreme right tilt  (Read 6462 times)
Offline Scott & Heather
  • MCI-9 & MCI-102
    • Fresh Day Music
Re: 1998 DL3 extreme right tilt
« Reply #15 on: November 25, 2020, 07:41:48 PM »
Get a new valve and replace it. This isn’t complicated. Seriously. I’ve done this before and it’s not rocket science. If it still gives you fits, install a manual leveling valve. I did and never looked back. And when you capitalize or BOLD it’s internet yelling
Offline Swadian
  • Jr. Member
« Reply #16 on: November 25, 2020, 07:48:29 PM »
I'll order it on Friday.
Offline chessie4905
« Reply #17 on: November 25, 2020, 08:49:56 PM »
Yes it is the valve. With rod or link disconnected, arm should move up or down, air  in system or not. Your temps aren't  below freezing are they? If they are, try warming leveling valve with a heat gun in case of ice in unit.
« Reply #18 on: November 26, 2020, 06:19:57 AM »
Will the back of the bus raise when you push the button ? if so raise it the Norgern valve bypasses the leveling valve then you can block it and crawl under it easy,me at the shop I remove the wheels to change the valve it is easier for old guys without a pit
Offline lvmci
  • lvmci
« Reply #19 on: November 26, 2020, 10:03:25 AM »
MCI Tech support 8003231290, speak to Jim or Boris for older busses...
MCI 102C3 8V92, Allison HT740
« Reply #20 on: November 26, 2020, 11:08:08 AM »
He is in touch with MCI support,he is saying the whole right side none of the air bags are filling
Offline Dave5Cs
  • BCM Subscriber
« Reply #21 on: November 26, 2020, 02:22:15 PM »
 After blocking the body, I would disconnect the supply line to see if you are even getting air through it. If not then you have to figure out why. If yes then it is your Valve.
