Author Topic: Wintering in a purpose built coach  (Read 11149 times)
Offline chessie4905
Re: Wintering in a purpose built coach
« Reply #30 on: December 20, 2020, 01:07:21 PM »
most of that black is years of diesel soot and fumes  just because tailpipe is at rear, it still gets althrough the body. First discovered this in the Olds diesels, of which I had a few. After a lot of miles, you could see it around the fabric. Back then, not  much of a concern. You could really see it on school busses. Someone cracks an orange in last seat, you could immediately smell it upfront in drivers seat. Werent allowed to eat on the bus back then.
Offline sledhead
« Reply #31 on: December 20, 2020, 01:36:30 PM »
by far the best thing I did with my 1990 M C I was framing out all the metal frame work with 3/8" ply and framing down the ceiling for more insulation and  having the shell spray foamed at the start of the build . and yes there was little to no insulation in there from M C I
dave
dave , karen
Offline chessie4905
« Reply #32 on: December 20, 2020, 02:26:35 PM »
another benefit is how much quieter and solid feeling it makes the coach.
Offline Jim Blackwood
« Reply #33 on: December 20, 2020, 04:09:19 PM »
dave
I'm not sure that's true of the '96. It seems to have insulation. There's 3" of fiberglass in the escape hatches for instance. Why would they bother if they didn't also insulate the roof?
Offline sledhead
« Reply #34 on: December 21, 2020, 04:51:50 AM »
there was only about 1 1/2" of crappy fiber glass in the shell , sides , roof with more in the floor but not much . as the only time the bus was used in service was when the engine was running with the heat or a/c on . not good for dry camping
dave
dave , karen
« Reply #35 on: December 22, 2020, 02:24:31 PM »
That's all the S&S's have.
Offline sledhead
« Reply #36 on: December 22, 2020, 02:29:26 PM »
maybe the shitty low end ones but not the high end built for a customer to the way they wanted it
dave
dave , karen
Offline hogi6123
« Reply #37 on: December 23, 2020, 05:58:55 AM »
The '94 MCI we're taking apart had all the voids in the roof packed with fiberglass, even inside the beams.  The walls are filled with preformed tight fitting foam panels.  It seems pretty decent for a vehicle.  (Also water leaked in apparently at the end of the rain gutters and rusted through the side panels and a tiny bit of the wall frame, so that is probably a place for you to reseal. I can send pictures of the damage if you're interested.)
I replaced the roof on a cheap travel trailer.  It had about 1" of fiberglass sparsely applied.  I filled the voids with fiberglass, except for one where a fan could have been mounted.  That spot was hot to the touch with the sun shining down, but the rest of the ceiling was not, so fiberglass is definitely useful.
We spent a month in my 1981 MCI this summer.  It feels like it doesn't have much roof insulation.  I really wish it were more insulated but there is no way I'm tearing everything up to redo the insulation in the roof.  If I ever buy another coach I will look for one that is partially done that I can insulate and finish or one that has been completed with good insulation from the beginning.
1981 MC-9
« Reply #38 on: December 23, 2020, 06:29:27 AM »
20* in New Mexico this morning the CC RV with double pane windows and the foam insulation is doing ok,the floor heat is on my bays are at 76* nice inside the Aqua Hot comes on 2 to 4 times a hour for a few minutes  and my engine is 130* ready to go lol Buddy the std poodle loves the floor heat I kinda like it too
Offline dtcerrato
« Reply #39 on: December 23, 2020, 07:07:17 AM »
Don't you just love it when a plan comes together. Sounds like pooping in tall clover! :^
Dan & Sandy
North Central Florida
PD4104-129 since 1979
« Reply #40 on: December 23, 2020, 07:31:10 AM »
Dan thanks for confirming my idea on the check valves the Aqua Hot hasn't missed a beat since I remounted those
Offline dtcerrato
« Reply #41 on: December 23, 2020, 07:39:39 AM »
Dan & Sandy
