Author Topic: Fuel Prices  (Read 5338 times)
Offline belfert
Re: Fuel Prices
« Reply #15 on: January 04, 2021, 03:24:23 PM »
Both gasoline and diesel have been trending upward in the past few weeks here in Minneapolis.  I don't pay near as much attention to diesel prices over winter since my bus is parked in a snowbank until summer.
Re: Fuel Prices
« Reply #16 on: January 04, 2021, 04:37:52 PM »
Heating oil in Alaska is similar to # 1 diesel (winter blend motor fuel) which is lighter that standard #2 diesel. It's similar to kerosene. Not sure about the lower 48.
Must be a gel problem in Alaska to use a lighter fuel kerosene has less BTU per gal than # 2 diesel
Offline chessie4905
Re: Fuel Prices
« Reply #17 on: January 05, 2021, 05:02:23 AM »
Since kerosene gels about -40, better to use up there than hoping the fuel supplier got the blended right. Had that happen back in the 80's here. We had a temp of -23 at home. Many diesels had problems with fuel gel. I ran kerosene in my Olds in January and February. Cheap back then and wasn't dyed. After that snap, the fuel dealers put enough in the blend to not see it happen again. They just jacked up the price to cover it.
Offline Knuckles
Re: Fuel Prices
« Reply #18 on: January 05, 2021, 06:13:46 AM »
Heating oil is kerosene also known as winter diesel , no 1 diesel , jet a fuel and is the lightest fuel. No 2 diesel also known as summer diesel is next then the thicker fuels like number 3,4 ,etc to bunker fuel
GM 4107 8V71  V730
Re: Fuel Prices
« Reply #19 on: January 05, 2021, 06:44:46 AM »
When # 1 fuel was the primary fuel for the Detroit's to help with the ash build up the Cetane was so low they were a bear to start in cold weather and the white smoke would roll for 5 minutes till one warmed up,going to # 2 fuel they ran better,started better and made more power and you didn't have all the injector problems with one.I overhauled a 6-110 Detroit a long time ago some person tried to run bunker C fuel in, that grade was almost asphalt
Re: Fuel Prices
« Reply #20 on: January 06, 2021, 10:23:55 AM »
During the '70's fuel crisis, an employee at the Hyperion Sewage Pumping (L.A.) plant started filling his Mercedes 240D with #3 Diesel fuel that they used for pilot fuel (think spark plug) for the dual fuel Worthington's that were used for pumping and air compressing. On the Mercedes, he did not recalibrate the injection pump and the hotter Diesel fuel punched holes in all 4 cylinders. An expensive experiment-ironic though when someone is stealing fuel.
