Author Topic: 4104, 4106 and later GM PD owners. . .  (Read 2246 times)
Offline RJ
  • Vantaré Conversion "Miss Vivian"
« on: May 19, 2021, 12:08:59 PM »
I no longer have my shop manuals or lube charts, so I need your help.
From the engine compartment looking forward, please share which side of the coach's centerline the rear axle's differential pumpkin is offset.  Is it offset to the driver's side, or is it offset to the curb side?
I know that there's a difference between the 4104 and the later models, I just don't remember which is which. One is offset to the driver's side (4104?) the 4106 and later to the opposite side (curb?)  Please help clear up my foggy brain cells!
TIA, troops!
Offline wildbob24
Re: 4104, 4106 and later GM PD owners. . .
« Reply #1 on: May 19, 2021, 05:00:35 PM »
RJ,
I happen to have a 4106 axle in my yard, so you can see for yourself:
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
PD4106-2546, 8V71, 4sp
Greenville, GA
Offline dtcerrato
« Reply #2 on: May 19, 2021, 06:50:31 PM »
4104 is offset to the driver's side
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Offline RJ
« Reply #3 on: May 20, 2021, 01:57:20 AM »
Thank you, Dan & Bob for the photos. I really appreciate you helping to answer my question!
Offline uncle ned
    • Visit: Busconversionstuff.com
« Reply #4 on: May 20, 2021, 09:23:53 AM »
For the experts.  Will a 06 pumpkin go into a 04 axle to correct the angle.
Just remember working with Jarra Smith the former owner and builder of HUGGY.
He put several 6v92  v730's in04's.
to old and stiff to crawl under huggy to check what he did to correct the angle problem.
Saw a o4 with a 8v71 and v730 and he said he was running th 04 rear end.
That has been a few years ago.
Dan our old friend out of Winston Salem also did a bunch and he said Jarra and he did it a lot of different ways.
If the diesel gets better I am still trying to get down to Gene's for a good check up.
Sure do miss David. He is a lot closer.
uncle ned
4104's forever
6v92 v730
Huggy Bear
Offline Bill Gerrie
« Reply #5 on: May 21, 2021, 04:47:51 AM »
Many years ago I talked to a couple of guys in CA that had put 8V71/V730 in 4104's and they had to use the 4106 rear end. The original 4104 rear end angle caused vibrations.
