Author Topic: Engine intermittantly running rough  (Read 4120 times)
Re: Engine intermittantly running rough
« Reply #15 on: September 21, 2021, 02:49:34 PM »
What is the size of the inlet on your pump ? and you cannot use the filter that come with those pumps unless you are into changing the filter every week you need 3/8ths inlet and out for  the min.
Offline dtcerrato
« Reply #16 on: September 21, 2021, 04:35:49 PM »
All the lines are 3/8" ID or larger. The engine runs really smooth & steady @ no load. The by pass really prioritizes the OEM feed to the engine mechanical pump - anything different & the pump pressure decreases. It's all good now & ready for a few day road test (we hope)!
Dan & Sandy
North Central Florida
PD4104-129 since 1979
« Reply #17 on: September 22, 2021, 07:06:14 AM »
The check valve on the suction side causes problems with restrictions too I move those to the return side per a Detroit service bulletin issued in the late 70's
Offline dtcerrato
« Reply #18 on: September 22, 2021, 03:44:30 PM »
Thanks! You just added an item to my list.
Dan & Sandy
Offline someguy
  • In the planning stages of converting an E/J4500.
« Reply #19 on: September 23, 2021, 06:55:21 PM »
"The pump is a high volume pump ($400) so no cheap one."
It's a myth that diesel engines need a huge fuel pump.   A 6-71 makes about 200 HP.   At a BSFC of 0.40 (which is high), it needs 80 pounds per hour.  Diesel fuel weighs 7 pounds per gallon, so less than 12 gallons per hour.
2 stroke DDs have a gear fuel pump built into them.   About all they need is unrestricted suction and they work.  In a truck tractor application the fuel tank pickup is ~ 2 feet below the engine when the tank is empty.  In industrial applications, the tank bottom can be further down than that.
« Reply #20 on: September 23, 2021, 08:16:14 PM »
2 strokes only burn about 1/4 of the fuel the fuel pump supplies the rest is used for cooling the injectors a 2 stroke should return .9 GPM.I never saw a built in fuel pump on a 2 stroke before you learn something here everyday.I have seen the pumps driven off the blowers and fuel pumps driven from the auxiliary drives but never a built in fuel pump before
Offline someguy
« Reply #21 on: September 23, 2021, 08:17:58 PM »
I meant the pump driven off the front drive.   Built into the engine.
