Author Topic: Why is the front axle so rough on this bus ?  (Read 3643 times)
Offline someguy
  • In the planning stages of converting an E/J4500.
« on: September 26, 2021, 11:08:42 AM »
The front axle on this bus seems to really jolt the bus when going over pavement cracks.
This is an early 2000s Prevost H3-45.
https://youtu.be/jh5zGBM5kuA?t=344
Am I imagining this to be harsher than it seems in the video ?
Is this bus suffering from loose suspension bushings or worn out shock absorbers, allowing the axle to bottom slightly ?
Were the MCI9s with air beams smoother in this regard ?
Are the IFS buses smoother ?
Offline lostagain
Re: Why is the front axle so rough on this bus ?
« Reply #1 on: September 26, 2021, 11:45:15 AM »
Even brand new Prevost H cars ride rough and harsh over rough roads, especially empty. The newer H3s have the IFS as an option, but they are rare, as it is expensive and most operators don't order them that way. That is why I prefer the MCI J because they come with the superb ZF IFS. Smooth as silk. Prevost, as good a coach as it is, is overrated in my opinion. I'll take a MCI anytime.
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Offline chessie4905
« Reply #2 on: September 26, 2021, 12:10:57 PM »
14,16,20 ply tires over potholes or really rough sections of roads at slow speed with 100+ tire pressure is harsh in any coach. Loaded to close to front axle max rating will smooth out a lot. Also loose kingpins, front end bushings, etc will also bang.Even in our 4104, hitting a smaller pothole at low speed could result in a stream of swear words. sort of like knocking fillings loose.
Offline someguy
« Reply #3 on: September 26, 2021, 12:22:20 PM »
IFS started on J4500s in 2014.  MCIs older than this have a straight front axle.    How do they ride in comparison ?
Prevost H3s have had IFS since 1998.   I wasn't aware that you could order them with a straight axle.  I thought they all had IFS.   The bus in the video is newer than 1998.   It should have IFS.   And yet is rides pretty harshly, from what I can tell, over those joints.
MCI retuned the front suspension on the Js.   Here is the company that did the work.
https://www.randle.co.uk/case-studies/mci-renaissance/
« Reply #4 on: September 26, 2021, 06:29:18 PM »
Tires don't help on a H-45 they are so front end heavy you need to max the air pressure anyways,I know it is a option on later H-45 for IFS but I never saw one yet. IFS has been around since 1996 on the XL our 1997 was IFS and was very,very exspensive to keep up that is why I got rid of it and went back to my old Eagle that had a trouble free IFS since 1958
Offline Busted Knuckle
« Reply #5 on: September 27, 2021, 08:12:25 AM »
Yup and since the Setra's and Eagles were both originally Kassboro  built Setra has always had excellent trouble free IFS too!
Offline someguy
« Reply #6 on: September 27, 2021, 08:40:09 AM »
Good point.  I wonder how much oversized steer tires would help the ride. 315s ?  335s ?  They would also give the front axle a bit more flotation in soft ground conditions.
« Reply #7 on: September 27, 2021, 08:50:32 AM »
You need to google them more!
Now days most Prevost come with 365's!
Offline buswarrior
« Reply #8 on: September 27, 2021, 09:47:07 AM »
BK, the learning here is incredible!
Most of what I knew, turns out to be rubbish.
Even Cliff is learning things!
I look forward to every log-on for what's next.
BCM is getting almost as good as social media?
Offline Utahclaimjumper
« Reply #9 on: September 27, 2021, 11:50:03 AM »
 BW,,, that's because your out in the sticks..>>>Dan  ::)
Utclmjmpr  (rufcmpn)
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Offline someguy
« Reply #10 on: September 27, 2021, 03:00:18 PM »
I did not know that, thanks for the heads up.   For the weight the front axle carries, they should be running 365s of the front.
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
« Reply #11 on: September 27, 2021, 04:00:59 PM »
For the weight the front axle carries, they should be running 365s on the front.
Prevost has been running 365s on the front of their buses for the last five, maybe even 10 years now. . .
FWIW & HTH. . . ;)
« Reply #12 on: September 27, 2021, 04:16:02 PM »
The 365 tire was made special for Prevost at 1 time Michelin was the only manufacture
Offline chessie4905
« Reply #13 on: September 27, 2021, 04:21:15 PM »
go for a ride on a PrevostCharter bus and ride up front. then you'll get an idea.
« Reply #14 on: September 28, 2021, 07:06:07 AM »
Yes the fronts were what I was referring too!
