Wow JC, Sorry you are having multiple headaches. I am NOT a mechanic and ask Buswarrior and BK and others to jerk the reins on my idea if I am sending you down a wrong path. I will take a picture of the air cylinder on my 6V92 in the morning.Also remember I don't have an MCI but that shouldn't matter. My engine quit running a few times on a trip. (at 65 miles per hour. that was fun). Long story short I had recent service and knew I had clean fuel, fuel filters, oil was new and full, coolant full. All gages normal before shut down(s). And I had been running 5 hours before it hit.I got two mechanics on the phone and they agreed, so I let them talk me through bypassing the engine run relay. Looked at my schematic, sent them a picture, and on the phone they had me move a wire so it bypassed it and they had me loosen one bolt on the air cylinder so I could swing it to the side to keep from shutting the engine off.Kind of spooky because as they said it would do once I bypassed that, I had no gages and no jake until I could make it 3 hours away to a guy that replaced that relay. Alllll better. So if you know your panel, that is a maybe, but the guys that correctly diagnosed that said that relay going bad is rare. When I told them I had new everything else, they both said check that with an tester. I did. It was bad. Probably not your problem but it shut me down. Frustrating thing was the relay was dying slowly. Intermittent damn thing. I'd rather something just crap out completely than make me chase 5 other things scratching my head.Now you should listen to the experts. I'm guessing they will have you check fuel things...Best of luckTed
I forgot to mention that I am only building pressure to 95 psi or so even when I use a external air compressor. I don't hear any air leaking when I walk around the bus. I'm wondering why I can't air up to 120 psi?
Try setting the pressure on the governor P>S they work opposite of most pressure regulators screw those up after you remove the rubber cover to increase the pressure.You still have an electrical problem to deal with and it will keep shutting down till it is resolved.MCI parking brakes release at 80 lbs the parking valve is not supposed to pop up till the air pressure is in the 20lbs range,where did you hook the supply line for the compressor? you may not be filling all the tanks since that is a dual air brake system and the parking brake valve is not getting a signal from a empty air tank
With water coming out the wet tank and setting for a year you may need a 10 $ set of unloader valves under the head of the compressor and a new head gasket will probably get you up and going in 2 hours. Those tiny valves rust and won't open or close. Check the easy things first like the connections on the skinner valve, It is normally closed with power no air can reach the shutdown till you kill the power and the rod goes out with air on the air cylinder pushing against the shutdown lever on top of the governor that is how the shutdown works. Make sure your rear start switches are in the right position also, those toggle switches on the rear start can be a bitch sometimes. Check the ground wire on the Skinner valve if it breaks or has a lot of corrasion it will shut the engine down,since you have air building now it and it shuts down it almost has to be electrical
