Author Topic: Side marker light color  (Read 10732 times)
Offline epretot
« on: June 22, 2024, 01:29:26 PM »
Is there a rule regarding the color of a side marker light?
I quite like the white/ clear lens.
Mine are in need of replacement.
2000 MCI 102 DL3
Loveland, OH
Offline windtrader
Re: Side marker light color
« Reply #1 on: June 23, 2024, 09:59:04 AM »
Similarly, I had questions about reflective tape colors, red, orange, all around, particularly the passenger and driver sides?
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
Offline chessie4905
« Reply #2 on: June 24, 2024, 05:00:53 AM »
White/clear lens with amber bulb.
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #3 on: June 24, 2024, 08:21:46 AM »
Are you referring to the Port or the Starboard side?  ;D
The red light indicates a vessel's port side; the green indicates a vessel's starboard side.
Sternlight: This white light is seen only from behind or nearly behind the vessel.
Offline Iceni John
« Reply #4 on: June 24, 2024, 05:39:36 PM »
FMVSS 108:
https://optronicsinc.com/RESOURCES/FMVSSRequirements/TruckBUSMPVs.aspx
My understanding (but please correct me if I'm wrong) is that the vehicle must have all the lights/reflectors/etc that were required when it was new, which are not necessarily today's requirements.   My 1990 bus did not come from the factory with all the lights needed now, but it's still legal (I hope).
2kW of tiltable solar.
  • Publisher - BCM
  • Administrator
    • BCM
« Reply #5 on: June 25, 2024, 07:03:12 AM »
FMVSS 108:
I heard the same thing, so I assume this is true.
Offline plyonsMC9
  • Global Moderator
  • Big Wheels Turnin'
    • PhilLyons.com
« Reply #6 on: July 13, 2024, 07:37:59 PM »
Optronics link seems to match what I've seen on the road. Esp for our buses > 30' length, intermediate side markers, amber.  Link is very helpful.
Kind Regards, Phil
Offline RJ
  • VantarĂ© Conversion "Miss Vivian"
« Reply #7 on: July 18, 2024, 01:51:42 PM »
Epretot -
Basically, the rule states that side marker lights in front of the rear axle must be yellow/amber.
Side marker lights behind the rear axle must be red.
Clear lens with appropriately colored bulb might be ok, try at your own risk.
Offline epretot
« Reply #8 on: July 19, 2024, 04:04:36 AM »
Agreed.
I'm went with the clear ones.
If I have to change them it would take 30 min.
2000 MCI 102 DL3
Loveland, OH
