Take the air line off the shut down cylinder 1st and see if the skinner valve is working both ways off you should air, starting and running you should have no air to cylinder,they do have a vent on the front plate with the 2 screws they also have a spring inside to return the piston with no air,they vent at the skinner valve,the vent on the cylinder is for when the piston extends for shut down
