Author Topic: GM baggage door gas struts  (Read 2882 times)
Offline FloridaCliff
  • "The Mighty GMC"
« on: May 09, 2006, 07:04:10 PM »
Anyone ever replace the torsion springs and use gas struts?
If so, source for parts, diagram of setup or picture.
Cliff
Mark Twain
Offline Cary and Don
Re: GM baggage door gas struts
« Reply #1 on: May 09, 2006, 08:25:59 PM »
Our 4107 had the springs replaced with struts when we got it, one on each side of the opening. They work fine.  They had to shim them out from the opening a little to clear when opening and closing the door.  Cary
1973 05 Eagle
Neoplan AN340
  • "The Mighty GMC"
« Reply #2 on: May 10, 2006, 04:20:01 AM »
Cary,
Any chance you could attach a couple of pictures?
Also are there any part numbers on the struts?
Cliff
Mark Twain
  • "The Mighty GMC"
« Reply #3 on: June 01, 2006, 04:02:47 PM »
In case any GM owners are interested!!!
Ed at Edannbus@aol.com has the mounts and information to switch from the torsion bars to a gas strut setup.
The mounts are 30.00 a door and the struts are 26.00 from the manufacturer.
I will post again on this after I get mine in. ;D
Cliff
Mark Twain
Offline tucsontattoo
  • 1962 4106
    • tucson tattoo
« Reply #4 on: June 01, 2006, 10:53:09 PM »
Cliff my 4106 has gas struts all around but the last owner said they were ripping the rubber hinges in the up position by putting constant pressure them. He drilled a hole at the top of each ram and tied a little pin to them to stick in the hole to hold them open. works fine but I think the problem could have been solved by moving the bottom mount of the strut down enough to let the strut extend fully before the door ran out of travel. any way now I will be replacing them a couple at a time. I think they will be great properly installed so thanks for the info on where to get them.
                                Tucson
      P.S.  thought I'd share this with you because it would be an easy mistake to make not thinking about the rubber hinge. Not the same as holding the door up on the back of an SUV.
we do things three ways,good,fast or cheap. PICK TWO!
  • "The Mighty GMC"
« Reply #5 on: June 02, 2006, 04:15:37 AM »
Tucson,
Thanks for the heads up.
I would definitely want them at max extensiion for the reasons you stated.
I should mention that I have replaced almost all the upper rubber hinges with the stainless steel ones that Ed sells.
That may eliminate any problems with a constant tension.
Thanks again
Cliff
Mark Twain
