Author Topic: mc9 cooling system  (Read 1562 times)
Offline ttomas
mc9 cooling system
« on: June 21, 2007, 08:53:41 AM »
Are there any alternatives to the dual squirrel cage radiator system? Mine throws alot of oil and I thought it may be just as well to change the system. Thanks Tom
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
Re: mc9 cooling system
« Reply #1 on: June 21, 2007, 09:54:20 AM »
Not unless you brew something up yourself.
You'd probably be best to pull the assembly and rebuild the gearbox. New seals, etc.
craig
  • Global Moderator
  • Nick & Michelle Badame
« Reply #2 on: June 21, 2007, 10:41:34 AM »
Hi Tom,
It may be easier to fix the oil leaks??  ;D ;D
Good Luck
Offline RJ
  • Vantarè Conversion "Vivian"
« Reply #3 on: June 22, 2007, 12:32:18 AM »
Tom -
MCI built over 9,000 MC-9s with that cooling system.
It may be marginal on hot days climbing Rocky Top out west, but it works.
Clean it up and fix it up RIGHT and you won't have to worry about it.
If you don't already have one, get a shop manual and parts book, well worth the $$$.
RJ Long
PD4106-2784: Donated to the Pacific Bus Museum
S14947: 1980 MC-5C Shell 6V92/HT-740
S13406: 1978 MC-5C Angola Coach - Swapped for vvv
M1001907: 1992 Prevost XL Vantarè Conversion 8V92T/HT-755 (DDEC/ATEC)
Cheney WA
