June 23, 2018, 06:03:04 AM
Author Topic: Cooling Solutions  (Read 5492 times)
Songman
Re: Cooling Solutions
« Reply #15 on: July 13, 2007, 01:52:44 PM »
Thanks Tom. I'll see what the boss (wife) has planned for Saturday. I would love to see what you have done with your bus so I'll definitely swing by if I can.
Offline David Anderson
« Reply #16 on: July 14, 2007, 01:22:36 AM »
Here are my fan pictures.
Picture 1 is the fan on the hub with a cardboard template to set the hole
Picture 2 is just the fan.
Picture 3 is the new metal shroud installed.   The bottom ran wild until I established the height, then I removed and cut it to length.  The shroud was made from 1/8" plate and I had a welder plasma cut the circle out of it.  on the back of the plate, I had him weld a 1" wide strap all the way around the hole.
« Last Edit: October 22, 2009, 04:19:16 PM by David Anderson »
« Reply #17 on: July 14, 2007, 03:39:19 AM »
What does that sound like from the outside when revved up-is it noisy?  My 8 blade aluminum fan is not noisy at speed, but definitely pulls the air.  Good Luck, TomC
« Reply #18 on: July 14, 2007, 04:31:02 PM »
It sounds like a small jet turbine, and it will suck you in when you walk by it at fast idle.
David
Dallas
« Reply #19 on: July 14, 2007, 04:37:17 PM »
David
How would I walk by at a fast idle?   :D :D
another question:
Isn't "fast idle" an oxymoron?  ;D ;) :)
Offline Busted Knuckle
« Reply #20 on: July 14, 2007, 06:54:12 PM »
Quote from: Dallas
another question:
Walking by at Fast idle is when yer just walking around kinda idle, But at a fast pace!
And I thought that oxymoron or something like that is one of those hybrid gases like Oxy Acetylene or like that!
Songman
« Reply #21 on: July 14, 2007, 10:02:58 PM »
Tom, it was nice meeting you and Don this afternoon. I learned a lot. You both know your stuff! That's the kind of interaction I need to keep me inspired on my conversion.
« Reply #22 on: July 15, 2007, 04:24:35 AM »
Hopefully will see your RTS in the near future.  Email me anytime if you have a question.  Good Luck, TomC
