Author Topic: alcoas  (Read 1446 times)
Offline tekebird
alcoas
« on: September 30, 2007, 11:23:46 AM »
anyone interested in some new Durabright Alcoas  22.5's
email me directly at tekebird@yahoo.com
there are 20 of them available, I am still trying to decide if I should get 2/4 or 6 of them.
Offline Jerry32
Re: alcoas
« Reply #1 on: September 30, 2007, 02:10:31 PM »
You didn't say where they or you are at. Jerry
1988 MCI 102A3 8V92TA 740
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
Re: alcoas
« Reply #2 on: September 30, 2007, 02:15:47 PM »
Any 24.5's available?
How much $$$ are they?
Offline tekebird
Re: alcoas
« Reply #3 on: October 02, 2007, 05:36:02 PM »
only 22.5's and down to 10 available.....may only be 6 if I decide to do the duals in and out
Offline NJT5047
Re: alcoas
« Reply #4 on: October 02, 2007, 07:34:51 PM »
Watch the stud length with dual aluminum wheels.  If you're going from steel, they'll likely have to be changed out.   When changing, consider the width of two aluminum wheels.
The inner is going to be screwed by facing the hub.  The steel wheel, assuming it's a 22.5 also, would be a good inner dual.   Weight isn't an issue on a bus.
Are you running hub piloted wheels now?
You probably know about this, but, for those that don't, you cannot install aluminum wheels on steel wheel studs...not typically.  And, the hub/lugnut design must match.  The studs can be changed to accomodate the additional thickness of aluminum wheels.
JR
JR Lynch , Charlotte, NC
Ayn Rand
