June 24, 2018, 05:37:33 PM
Author Topic: basic question re: 40W oil. Where do you buy it? And what's a good price?  (Read 9788 times)
Offline zubzub
    • pics of my bus etc....
Not feeling fussy after trying Oreilly's for Delo 100, tried a chevron distributor they need 2 weeks lead time.  Walmart in Duluth doesn't stock 40w of any kind.  I guess I could haul it from montreal, but that is silly.  So...what's between chicago and duluth mn that will have 40 wt for me?  Didn't think this would be so hard.  Ah the little things.
Also does anyone have the napa part # for the oil filter "53 4104 with a 6-71? Thanks, Patrick.
p.s. I think I'm up to speed on the oil just need to know where to buy it.
« Last Edit: October 30, 2007, 09:56:50 AM by zubzub »
If you change to Shell Rotella you can buy it at most Napa stores for 10.95 a gal DD dealers sell 40w for the the 2 strokes for about the same price
« Last Edit: October 30, 2007, 10:08:57 AM by luvrbus »
Offline JohnEd
ZubZub,
I called a few "oil dealers" around here in Portland,Or.  I got a lot of different prices and the best was $9.48/ gal in 5 gal "buckets".  Shop around and buy from the cheapest source.  You are buying the CF-2 spec for two cycles so the brands don't differ that much but they certainly do differ.  Mostly in the ash content.
Happy hunting,
Offline gus
In your cold country I would just use the "Heavy Duty" 30W oil from WM until warmer weather. It comes in blue two gal plastic jugs and is around $13-15 for two gal. Look on the back label and make sure it says CF-2. It most likely will because that is about the only single weight sold in large containers. They may even have it in 5 gal buckets.
I tried to get the WM manager here to order me some 40W but he wasn't interested.
Farm stores are another good place to look.
Chevron is almost impossible to find since they were bought out by Shell.
Marinas are a good place to look, I found some good prices at a marine store in Seattle last spring.
Oil prices have gone up so expect to pay $10+ almost anywhere.
Offline RJ
Gus -
I didn't know Shell bought Chevron.  I know Chevron bought out Texaco a couple of years ago.  When this this take place?  I couldn't find anything about it using Google.
ZubZub -
If you go to Chevron's website, they have a dealer/distributor locator to help you find someone in your area.  Expect some delay, most don't stock Delo 100, but can usually get it within a few days.  Which means - plan ahead.  Order at least two cases (six gallon jugs per case) so you've got enough for an oil change and extra.
Ten bucks a gallon sounds about right, with current oil pricing.
RJ Long
PD4106-2784 No More
Cheney WA
Offline dvrasor
 Just bought a 55 gal. drum of Delo 100 40wt. in orlando two weeks
 ago for 500.00.Taxes and compliance fees were 38.18. That was
 delivered to my door. Total 538.18.
        Dave Rasor 4104-2375
Offline DrivingMissLazy
That equates to $9.79 per gallon.
Offline buswarrior
  • '75 MC8 8V71 HT740
As noted, older boats, older construction equipment, bus fleets all have DD's in them and need the right oil. Ask around as to where they get theirs.
Gotta be a DD dealer somewhere in the neighbourhood.
Nothing wrong with buying a drum and put it in all your stuff...
beyond warrenty coverage, that is!
Offline Barn Owl
  • Roanoke, VA
  • PD4106-1063 "Wheezy Bus"
I’m not sure why there is never much mention of Exxon’s XD-3 when this subject pops up. It’s better than the Rotella according to the tejas web site (http://www.tejascoach.com/tips.html). In my town it was very easy to find and the price was better than my other oil options.
Zubzub, you don't have to use Delo 100  you can use Delo 400 or Delo rpm now since they have removed most of the ash on the new oils.i know people will disagree but if you go to Chevron Delo 400 engine oils on the web and you will see that they are DD 2 stroke specs and the 400 in 40w you can also buy at Napa Auto Parts.forgot to post the address  http://www.chevron.com/products/prodserv/nofl/trucking/content/prods
« Last Edit: October 31, 2007, 11:57:41 PM by luvrbus »
Offline RJ
Re: basic question re: 40W oil. Where do you buy it? And what's a good price?
« Reply #10 on: October 31, 2007, 10:57:08 PM »
Luvrbus -
Sorry, but that's not quite accurate.
If you surf thru Chevron's site to the Product Data Sheets, it specifically says on the Delo 400 page that, and I'm quoting here:
"Chevron Delo 400 oils are not recommended for use in DDC two-stroke engines."
If you view the PDS for Delo 100, you'll find this:
Chevron Delo 100 Motor Oils:
• meet API Service Categories
— CF-2, CF, CD-II1, CD1
• comply with Detroit Diesel Corporation two-stroke engine recommendations, including the 0.85% ash maximum limit for Series 149 engines.
At one point in time, D-400 was CF-2 rated, but no longer.  Also, D-400 is most commonly found as multi-weight 15-40w, and Detroit is pretty clear about not using multi-weight oil in their two-strokes.  And many a busnut on this site will confirm the difference with their own coach when switching to the correct CF-2 oil, be it Chevron, Shell, Exxon, etc.
As I said before, the correct oil for our two-stroke engines is available, you just have to plan ahead.
RJ Long
PD4106-2784 No More
Cheney WA
« Reply #11 on: November 01, 2007, 12:24:42 AM »
Russ, heres the quote from Chevron
 Chevron's primary recommendations for the two cycle diesel engine is Delo 100 specifically for the DD 149 diesel engine
We recommend Chevron RPM heavy duty sae 40 or 50
Delo 400 sae 30,40 and 50 meet the requirements of API CF-2 and are also recommend for the two cycle diesel engines
@2007 Chevron Products CO San Ramon CA
« Last Edit: November 01, 2007, 12:29:18 AM by luvrbus »
Dallas
« Reply #12 on: November 01, 2007, 05:45:17 AM »
Where, exactly did you find that quote?
I looked through all of the product data sheets for the different types of Delo 400 and can find No reference to these oils meeting API CF-2. All of the Specifically point out that they are for Detroit Diesel 4 stroke engines.
Offline zubzub
« Reply #13 on: November 01, 2007, 07:17:28 AM »
http://www.chevrondelo.com/en/deloworldwide/uscanadamexico/default.asp#multigrade
 half way down the page it states... that the delo 400
• Available in SAE 15W-40. Also available in monogrades SAE 30, 40, and 50, which meet API CF-2 requirements and are also suitable for two-stroke diesel engines.
 If you go further down the page under the specs of delo 100
Applications
• Delo 100 Grades SAE 30, 40, and 50 comply with Detroit Diesel Corporation's two-cycle engine recommendations for the 71 and 92 Series
So from my unlearned position, Delo 100 is the way to go, but...if you have to, single weight delo 400 might do.  When I talked to a Chicago distributor for chevron she told me up top 2 weeks lead time required for the 100.  Since NAPA seems to stock a reasonable oil this is all mute really.  But when I have time I'll order the Delo 100 as on paper it sure seems best. re lowest ash etc....
Patrick.
« Reply #14 on: November 01, 2007, 07:28:53 AM »
I believe it is pretty plain in this data:
Applications
• Delo 100 Grades SAE 40 and 50 meet the viscosity and 0.8 percent ash limit for DDC Series 149 engines
• Two- and four-stroke diesel engines in farm machinery, construction equipment, marine, and other off-highway applications
Select Performance Specifications
SAE, 30, 40, 50: CF-2, CD-II (obsolete specification)
All grades: CF, CD (obsolete specification)
Compliance with Detroit Diesel Corporation two-stroke engine recommendations
