Hello: Mike from Dunnellon fl.. 72 mci 7 Have a relative in Washington Pa .. south of Pittsburg.. (same town ??) hope to be up there next spring. Will get in touch if it is all right with you.. FWIW always used the block heater for 2 hours when back in upstate NY. never failed 45 or below . Happy Bussin mike
Great, another cabinet maker on the board! Maybe you and Cody should get together and put on a seminar at one of the rallies! Like maybe TBR 2008.Or any other rally that could benefit from your expertise.I know I sure could. I almost apologize for hijacking the thread. Paul
I just thought there may be an easy fix or a trick you folks know that I did not....
Just so you all know- the spray starter fluid is spelled ether- not either.
QuoteJust so you all know- the spray starter fluid is spelled ether- not either.That's what happens when I try to do a 10 sec post at work. I am amazed at how much better I spell at home.
