Author Topic: Rear brake valve rebuild and parts-brass air line end fittings? MCI9  (Read 1401 times)
Offline grantgoold
I have to RR my rear brake valve. I have already ordered the kit and will get that done shortly. It removing the valve, I noticed that the large air line (1 inch I.D) connects to the valve with a 1 inch to 1/2 inch adapter body. I am having a difficult time finding a brake line supplier with an adapter body that large.
Anyone know of a  supplier that carries air line end fittings so large?
Thanks in advance!
Grant
Grant Goold
1984 MCI 9
Way in Over My Head!
Citrus Heights, California
Offline Ednj
  • Ed & Sue Skiba
Re: Rear brake valve rebuild and parts-brass air line end fittings? MCI9
« Reply #1 on: November 13, 2007, 05:38:48 AM »
http://www.suicidedoors.com/FittingsHexReducingNipple.php
They will have it , give them a call. ;)
MCI-9
Sussex county, Delaware.
Offline ChuckMC9
« Reply #2 on: November 13, 2007, 06:27:52 AM »
Grant, to help me in my air system education, are you speaking of the relay valve? If so, what symptoms what the valve exhibiting? I'm getting a late start in understanding the functions of all components of the air & brake systems - just replaced my rear actuators last week - and would like to know all I can as I go forward looking at everything.
Thanks!
Offline grantgoold
« Reply #3 on: November 13, 2007, 07:12:54 AM »
Chuck, the vavle sits just to the left of the passenger side leveling valve. The tag on the vavle says brake valve with a pressure of 85 psi. The valve was leaking around the gasket. In tear down, the gasket was old, dry and cracked.
I am only thinking that this valve supplies the rear brakes. I have not had a chance to look at the repair manual yet. My brakes were working fine. I just wanted to stop the leak down.
Grant
Grant Goold
1984 MCI 9
Offline ol713
    • ol713
« Reply #4 on: November 13, 2007, 07:29:03 AM »
Hi;
    You maight also try Motion Industries.  They should
    be in the phone book.  I am replacing the fuel lines
    in the engine compartment and they had the right
    stuff. Look under industrial supply in the phone book.
                                       Good luck,  Merle.
