Author Topic: spring brake conversion should i  (Read 6848 times)
Offline Utahclaimjumper
Re: spring brake conversion should i
« Reply #15 on: November 21, 2007, 03:08:59 PM »
George, as soon as I get back this week end from a trip I'll look for the pot numbers, by cutting in half I mean I used an abrasive saw and cut them cross wise, then useing a 1/2 inch thick by 3 cold rolled tab I off set them to line up with the newly mounted pot push rods and clevises, welded them up with low hydrogen rod for strength. They have been working great for ten years, I found several years later that the offsets were available across the counter.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Offline 4106-123
  • Jr. Member
« Reply #16 on: November 21, 2007, 03:42:53 PM »
dan did you also have to relocate the pot mounts?
Offline pvcces
« Reply #17 on: November 21, 2007, 06:44:14 PM »
We had our spring brakes installed by Southern Oregon Diesel about six years ago. I don't know if they will do the alteration anymore.
The mounting pads for the original cans were cut off of the air beams and the air beams notched just enough to allow remounting of the pads; they got one of them 1 1/2" and the other one 1 3/4" closer to the axle. Both cans use the original slack adjusters and either one can be removed from it's mount without disassembly of the can.
This left an inch or so of clearance between the cans and the bulkhead. They have always worked perfectly.
It's important to get the mount strong enough; 30 inches times 125 psi is a bit less than two tons of force, so the welding needs to be able to handle a suitable safety factor. I think that 6 to 1 is a good target, so make the bracket weld capable of standing 12 tons of force.
Also, be sure to get the air supply from the brake side of the system, not the auxiliary side. The brakes have to be able to work with an air line ripped off of the suspension, etc.
For what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Offline Barn Owl
  • Roanoke, VA
  • PD4106-1063 "Wheezy Bus"
« Reply #18 on: November 21, 2007, 09:24:47 PM »
I like mine. It is a tight fit.
Offline 4106-123
  • Jr. Member
« Reply #19 on: November 22, 2007, 08:17:32 AM »
barn owl did you have to relocate the mounts?
Dallas
« Reply #20 on: November 22, 2007, 08:56:36 AM »
I like Relocating to Spring Break!
Maybe I'll go with BK this year!
(Can I Bryce, Can I? hunh, Please, Please, Please?)
Offline PADoug
  • Squirrels store food in bus. Are they bus nuts?
« Reply #21 on: November 22, 2007, 10:05:11 AM »
Dallas Dallas Dallas..We're talked about Buses, not getting BUSTED.  :D
Besides, from what I hear, you are the "Cat's" meow anyway.  ::) Wish I had a woman like that. (Does Cat have a sister, say in the 20-40 range? I have family down in TN, so a "visit" might be in order...LOL) Tell ya what; I'll apply for BK's "School of Instruction" about Spring Break and maybe learn a thing or two about "DD3's" while I'm at it.
By the way, I thought spring brakes were standard on most of the GMC's. I was considering a 4905 several years ago (before I became poor). I guess I didn't know what I was looking at. (Now that I've joined the boards, I'm learning so much more). :)
Doug
Living life one day at a time, and keeping first things first. MM Philanthropy#225 F&AM Greensburg, PA
Offline Barn Owl
  • Roanoke, VA
« Reply #22 on: November 22, 2007, 08:05:41 PM »
Quote
PO had the mod done. I wish I could be of more help. I like them and think it would be worth the trouble to make the changeover. Whoever did the work did a good job. I cannot tell there was a mount change if there was one. I will look closer the next time I am under it.
Laryn
Offline Barn Owl
  • Roanoke, VA
« Reply #23 on: November 22, 2007, 08:10:56 PM »
Dallas,
I know what two of the three got for a graduation present!.. ;)
Offline JACKRABBIT4106
« Reply #24 on: November 25, 2007, 07:22:36 AM »
For those of you that have switched to spring brakes did you also install a SR1 valve and a DC4 valve and where did you mount the extra air tank? Barn owl could I get you to take a pic from bottom up or top down?
Erik
Offline Barn Owl
  • Roanoke, VA
« Reply #25 on: November 25, 2007, 01:58:52 PM »
Erik,
I will take as many pics as you need. If it's not raining I will get up under it this weekend. Let me know what you are looking for.
Laryn
Offline 4106-123
  • Jr. Member
« Reply #26 on: November 25, 2007, 02:48:15 PM »
I WOuld also like to know how the air is routed as compared to the original system? were does the button on the dash lines go ect? thanks george
« Reply #27 on: November 25, 2007, 03:05:37 PM »
I am looking for where the brake pot mount is welded to the suspension. Are the chambers 30/30?
Thanks Erik
Offline Barn Owl
  • Roanoke, VA
« Reply #28 on: December 01, 2007, 06:52:58 PM »
 :( I didn't forget about you guys. Went out for some Christmas shopping and as always it took longer than planned. I will be under the bus soon because I am replacing the Sheppard steering box and the pump. My father is picking them up from NIMCO next week for me.
Offline Len Silva
    • Leonard Studio
« Reply #29 on: December 02, 2007, 09:56:42 AM »
Nearly everything you need to know is here:
http://www.bendixvrc.com/itemDisplay.asp?documentID=4631
Len
