Author Topic: power steering line  (Read 1494 times)
Offline David Anderson
power steering line
« on: December 03, 2007, 03:12:10 PM »
I made a modification in my power steering fluid line last year.  I replaced some rubber hose (low pressure) with 3' of type K 3/4" copper line strapped to the the bus frame.  This worked very well for the placement of the line in this situation.  That is why I chose it over more rubber hose.  I am now wondering if copper reacts with ATF in the power steering system.  Will this metal cause problems in the future?
David
Offline TomCat
  • It's 4:20 somewhere...
    • Jay's Conversion Pics
Re: power steering line
« Reply #1 on: December 03, 2007, 04:26:09 PM »
David,
The PO of my Thomas changed out the power steering pressure hose from front to rear, to a steel pipe about 3/4 inch in diameter. No leaks so far.
Sorry, no help on the copper question.
Jay
87 SaftLiner
Offline Sammy
« Reply #2 on: December 03, 2007, 04:52:28 PM »
I don't think so. The RTS transit bus uses copper pipe too.
Hope this may help.  8)
Offline Stan
« Reply #3 on: December 03, 2007, 05:15:11 PM »
I would be concerned about the pressure rating of the copper pipe. You know what kind of pipe you used and the pressure on your power steering so you can see how much safety margin you have in the charts in this link.
http://www.copper.org/applications/plumbing/techref/cth/tables/cth_table3a.htm
« Reply #4 on: December 03, 2007, 08:24:00 PM »
Pressure is no problem.  It is the return line, very low pressure.  I'm just concerned if there is any reaction of ATF with copper.
David
