June 24, 2018, 04:33:17 PM
Author Topic: Where do you get the Aluminum Molding for covering the seams?  (Read 5882 times)
« on: February 05, 2008, 10:57:34 AM »
I have googled, MAK search and Help. Could not find what I am looking for in aluminum trim moulding. I want to replace the trim that goes between the side panels on upper and lower. I would rather not have a plastic insert. Would like to find one that is similar to a half round with ridges on under side to go over rivets. Any suggestions on what is best?
Thanks in advance.
Offline DavidInWilmNC
Re: Where do you get the Aluminum Molding for covering the seams?
« Reply #1 on: February 05, 2008, 11:09:06 AM »
Paul,
Maybe something like what MCI used on the -8's and -9's right under the windows would work.  It's a long section of molding that's maybe 1-3/4" wide and maybe 1/4-3/8" or so tall (this is from memory so the dimensions may be off).  Perhaps somebody who removed it from their MCI would have it, or most parts buses would, too, I'm sure.  This is definitely not half round, but might still work for you.
David
Offline pete81eaglefanasty
    • smithmotorsports
« Reply #2 on: February 05, 2008, 12:23:39 PM »
 Hi Paul
 I believe what you are looking for, you can get from I B P They come in 20 foot length. I got a few from them.
            Pete & Jean
              FANTASY
  #1-800-468-5287
WHAT EVER YOU DO, OR TO WHO YOU DO IT TOO, DO IT WITH A SMILE, IT MAKES IT LEGAL THAT WAY.
« Reply #3 on: February 05, 2008, 02:48:09 PM »
David,
Thanks for the information. The width is about what I need, no less than 1 1/12".
Pete,
I checked their web site, didn't find what I need. I'll have to give them a call. The 20' length is perfect, as that is what the old stuff was.
Thanks for the help,
  • Global Moderator
  • Nick & Michelle Badame
« Reply #4 on: February 05, 2008, 03:11:17 PM »
Hi Paul,
I have IBP's PDF catalog on my computor and I can't figure out how to post it yet...
I also purchaced Eagle moldings from them and now that I'm thinking about it I think I have 2- 20' ers left...
    • smithmotorsports
« Reply #5 on: February 05, 2008, 04:19:06 PM »
I just look at their book it is called cover molding # BS 2272-141
them you will want to get  the Molding seal that goes under the aluminum strip it makes the strip fit and looks better. #BS 2672-318D
              Pete & Jean
                FANTASY
  • Global Moderator
« Reply #6 on: February 05, 2008, 05:01:48 PM »
Hi Paul,
This is the Eagle moldings that I installed on my bus.
Offline FloridaCliff
  • "The Mighty GMC"
« Reply #7 on: February 05, 2008, 05:37:29 PM »
Nick,
Send me the pdf as an attachment to my email, when you have a chance.
I have an interest in some mouldings also.
I couldn't find it online!
Cliff
Mark Twain
Offline muddog16
  • Example is more powerful than reproach. ~Aesop
    • Prevost LeMirage Conversion
« Reply #8 on: February 05, 2008, 05:40:18 PM »
I bought all of my trim from Austin Hardware they have a great catalogue  here is there website link:   http://www.austinhardware.com/
Pat
1982 Prevost LeMirage
8V92TA/HT754
« Reply #9 on: February 05, 2008, 05:41:55 PM »
Hi Nick,
What was the part number of the one you used?
Thanks for the help guys.
  • "The Mighty GMC"
« Reply #10 on: February 05, 2008, 05:48:23 PM »
Pat,
Thanks for the link.
Looks like they have what I need.
Cliff
Mark Twain
  • Global Moderator
« Reply #11 on: February 05, 2008, 06:49:28 PM »
Hi Cliff,
I was not able to e-mail it either???.  I have it on disc too..
Hope you have it now.
Offline mikeH8H-649
« Reply #12 on: February 06, 2008, 05:51:11 AM »
Cliff,I have a copy of IBP's pdf if you would like it,GM's are all most obsolete on it allthough they still make the panels for them they are pretty much a special order thing,Kathy and I were there a few weeks ago and Steve says there is just not much call for gm's anymore which makes sense,let me know if you want it and I will get it to you     Mike
Sojourner
« Reply #13 on: February 06, 2008, 07:58:43 AM »
http://www.extrude-a-trim.com/pdfs/Boat_and_RV.pdf
They have aluminum rub rail with 1/8" lip (over rivet) to screw on and snap vinyl trim to cover...made for RV.
It good idea to leave some gap on bottom of rub rail for moisture relief.
FWIW
Sojourn for Christ, Jerry
Offline boogiethecat
    • HeartMagic
« Reply #14 on: February 06, 2008, 04:34:54 PM »
McMaster has some really  nice stuff:
go to http://www.mcmaster.com/ and type "aluminum moulding" into their search engine, or go to page 3659 in their online catalog
I just glue it on with Sikaflex.... works great!
Cheers
Boogie
1962 Crown
San Diego, Ca
