BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Generator Quit
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Generator Quit (Read 5275 times)
BillC
Newbie
Generator Quit
on:
February 08, 2008, 03:04:46 PM »
The generator quit today after about three hours of use, the moter still runs ,it doesnt produce electric. There is an automatic transfer switch. It is a 3 cyl. kubota with a 7.5 head. It was running 2- 1500 watt heaters and the fridge, getting ready for our 3 week trip to Fla. tomorow am from cold north central Pa. I am not sure how to check the tranfer switch .
Logged
1983 Eagle 10 S
YeomansEagle
Newbie
Re: Generator Quit
Reply #1 on:
February 08, 2008, 03:22:26 PM »
I'm not sure about your Generator but mine has a cicuit breaker on the Generator and also in main Panel. I would suggest turning heaters & Generator off and checking the breakers. Maybe toggle Breakers off & back on. Then restart generator. As always be very careful when working with electricity.
YeomansEagle
Logged
Who the Son sets free is free indeed.
Lin
Hero Member
1965 MC-5a
Re: Generator Quit
Reply #2 on:
February 08, 2008, 03:56:41 PM »
Just to chime in on something that I know little about, I would guess that if you just stopped getting current suddenly and you do not smell something radically burnt, you probably have a relatively minor problem. As said above check your breakers first since that is the easiest thing to do. If reseting them (turning them off and on) doesn't do anything, then start from the beginning and work forward. That means test to see if current is coming from the generator. If it is, move up to the next link in the chain; that could be your transfer switch or a conjunction box, etc. If you find current, keep moving forward until you get to the problem. If you do not find current at some point, then you know the problem is in between that and the last place you had current. If you did not get current leaving the generator, look to see if there is a breaker integral to the genset or if some wires have become loose.
Logged
Kwajdiver
MCI-9 "Kwaj Diver"
Hero Member
Re: Generator Quit
Reply #3 on:
February 08, 2008, 04:13:42 PM »
Basic question, do you know how to check power out of the gen set, and at the transfer box? If not one of us will be glad to walk you through it.
Give me a call if you wish. 863-604-3701 anytime.
Bill
In Sunny Florida
Logged
Auburndale, Florida
MCI-9
Kwajalein Atoll, RMI
DrivingMissLazy
Hero Member
Re: Generator Quit
Reply #4 on:
February 08, 2008, 04:43:18 PM »
To do any testing it is imperative that you have a
voltage
tester. You can not test the unit by checking for current. You have to check for voltage. Either a trouble light of the proper voltage with test leads or an el cheapo voltmeter from Radio Shack or any automotive parts place. Then start checking for voltage at the circuit breakers and then downstream to the automatic transfer switch.
Logged
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body. But rather to skid in sideways, chocolate in one hand, a good Reisling in the other, body thoroughly used up, totally worn out and screaming: WOO HOO, what a ride
Sojourner
Guest
Re: Generator Quit
Reply #5 on:
February 08, 2008, 04:49:40 PM »
BillC...can you give us your brand & model no.?
This can reduce time, confusing to yourself & us. We can work from there more straight forward as what your problem may be.
Picture of generator/motor and transfer box can help....more so if don't have brand & model #.
We can give you step by step after above information achieved.
FWIW
Sojourn for Christ, Jerry
Logged
BillC
Newbie
Re: Generator Quit
Reply #6 on:
February 08, 2008, 04:55:22 PM »
I can not read the sticker on the gen head. the trans switch i will go read in a few mins. i have a 120 volt and a 240 volt tester with lead wires is this what you mean Richard thanks Bill C
Logged
1983 Eagle 10 S
Don Fairchild
Hero Member
Re: Generator Quit
Reply #7 on:
February 08, 2008, 05:07:56 PM »
Bill if the brakers are not tripped and you have no voltage I would sepect the voltage regulator next. I have a problem with mine in that it will run for a short time putting out voltage and then the engine will shut off, you can restart it and it will run for about 3 min and it shuts down again. I have not found the problem yet. Any suggestions.
Don
Logged
BillC
Newbie
Re: Generator Quit
Reply #8 on:
February 08, 2008, 05:20:41 PM »
I just tested the switch and the lead from the gen, the gen wire is not hot . Numbers on the head are salr11305 made in england BCX164A WD6 73 machine ID 97484844 The transfer switch had power when i plug in the shore power . Bill C
Logged
1983 Eagle 10 S
BillC
Newbie
Re: Generator Quit
Reply #9 on:
February 08, 2008, 05:34:42 PM »
I also took the cover off the top of the head and have no power there either . I did not smell anything burning and it all looks normal inside the box Bill C
Logged
1983 Eagle 10 S
Sojourner
Guest
Re: Generator Quit
Reply #10 on:
February 08, 2008, 10:43:43 PM »
Does it have brushes?
Winding not burned or black or blistered?
No picture yet....is it direct drive?
Is it blowing a lot of air from generator's fan.....would indicate if drive coupling is slipping!!
No brand name and/or picture is an opening to many suggestion.
In the mean time hope the right suggestion will fix it.
Picture may be your quickest responds with the fix.
FWIW
Logged
niles500
Niles500
Hero Member
ROSIE
Re: Generator Quit
Reply #11 on:
February 09, 2008, 12:46:06 AM »
Sounds like a bad breaker or reset needed at the Genhead - HTH
Logged
(\__/)
(")_(")
- Niles
Marcus
Jr. Member
Re: Generator Quit
Reply #12 on:
February 09, 2008, 05:24:17 AM »
Don ,I don't know what brand of engine you have on the genny, but I had the same problem with shutting down at times. I have an Izuzu diesel. It has oil pressure and temp sensors. I replaced both and my problem was solved. Marc
Logged
Kwajdiver
MCI-9 "Kwaj Diver"
Hero Member
Re: Generator Quit
Reply #13 on:
February 09, 2008, 06:23:40 AM »
I spoke with BillC last night. He is going to go ahead and head south to Florida Perhaps overnight in N.C. at a RV Park, so he can plug into shore power. Then Sunday, he'll come on down to Florida. He is headed for the Space Coast the first three night, name Satillite Beach. After that he is a little bit open. May come down Arcaida way, then over to Venice.
Somewhere along the way, we need to get him help with this problem. He can see no breakers at the gen set and believe's the gen set is producing no power.
What do you say, anybody around Jacksonville, Daytona, etc that can help?
Just (Sat 10:25a) spoke with Bill C's wife. They still hope to depart this morning.
Bill W.
Logged
Auburndale, Florida
MCI-9
BillC
Newbie
Re: Generator Quit
Reply #14 on:
February 09, 2008, 06:36:35 AM »
Hi Bill I just tore the top half of the gen head off, the rearbearing looks good alot of road dust in there blew it out and put it back together, i found no breakers or switches , i checked all wires in the box and still no power.We are leaving at 10 am sat morn with long johns and blankets looks like the aqua hot will be installed soon. See Ya on the SUNNY side [still snowing] Bill C
Logged
1983 Eagle 10 S
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
Generator Quit
