June 23, 2018, 12:34:28 PM
Author Topic: Zerk lube for MCI 9s  (Read 4120 times)
Offline grantgoold
« on: February 16, 2008, 05:58:09 AM »
What are people using as a good zerk lubricant for their buses?
Grant Goold
1984 MCI 9
Way in Over My Head!
Citrus Heights, California
Offline tekebird
Re: Zerk lube for MCI 9s
« Reply #1 on: February 16, 2008, 07:04:10 AM »
Grease
Offline JackConrad
  • Orange Blossom Special II
  • Global Moderator
« Reply #2 on: February 16, 2008, 12:40:58 PM »
I buy a case of Hi-Temp All Purpose cartridges for my grease guns.
Offline chazwood
    • Thekempters
« Reply #3 on: February 16, 2008, 12:50:40 PM »
The question isn't what to use in the Zerk's......
it's where are they all ? :)
1983 Eagle Bus Model 10
6V92
Thekempters.com
Offline buswarrior
  • '75 MC8 8V71 HT740
« Reply #4 on: February 16, 2008, 01:29:56 PM »
Everywhere, and then some!
Good quality chassis grease of your choosing will do.
And a good quality powered grease gun will mean you are more likely to get it all done without getting tired and start skimping...
Dallas
« Reply #5 on: February 16, 2008, 01:43:51 PM »
Yup, What BW said,
 and I'll add that you really need to purchase a grease zerk kit with a hundred or so extra zerks of all sorts in it. Also get a bunch of paper clips of different sizes to scrape out the old dry grease in those holes where you remove a plugged zerk. It probably hasn't been greased in years.
Good Luck, and have lot's of fun!
Dallas
Offline chazwood
    • Thekempters
« Reply #6 on: February 16, 2008, 02:04:25 PM »
No really... is there a one page map to all the grease fittings on a mc9? Or do you have to plow through the maintenance manual to find them all?
Someone should make a diagram and sell it. I'd buy one.
6V92
Thekempters.com
Offline grantgoold
« Reply #7 on: February 16, 2008, 02:55:11 PM »
Thanks for all the input especially the "grease" one that was good! ;D
I have the airpowered unit and will get to Napa today. My manual does show all lubrication points in the bus. I just took out a highlighter and marked those that are zerks and need the grease.
Good day!
Grant
Grant Goold
1984 MCI 9
Offline chazwood
    • Thekempters
« Reply #8 on: February 16, 2008, 03:43:35 PM »
well lucky you, you have a manual. :) Hint. Hint.
6V92
Thekempters.com
Offline Tenor
    • Three Men and a Tenor
« Reply #9 on: February 16, 2008, 04:08:06 PM »
Chaz,
I forgot to add that buses are engineered to transport Zerk fittings safely too! ;D
Glenn Williams
Lansing, MI
www.threemenandatenor.com
8v71
4 speed Spicer
Offline chazwood
    • Thekempters
« Reply #10 on: February 16, 2008, 08:15:38 PM »
Chaz,
You lost me here.  ??? refresh my memory....what were we talking about.?
Never mind...I just read your reply to the other post....now I get it. ;D That tank removal was brutal. I think I'd rather drop the engine than go through that again. :-\
« Last Edit: February 16, 2008, 08:20:19 PM by chazwood »
6V92
Thekempters.com
