BCM Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
BCM Home
Forum
Help
Forum Rules
Search
Login
Register
BCM Community
Bus Discussion
(Moderator:
Oil Filter
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Oil Filter (Read 5686 times)
loadera10
Newbie
1985 Eagle Model 10
Oil Filter
on:
March 01, 2008, 09:46:53 AM »
Hi, all I've just inherited a 1985 eagle model 10 that is in great shape. While changing the oil, I looked for the oil filter and didn't find one. I see the fuel, primary and secondary filters. Where could this oil filter bee? I've been top to bottom of this bus....Help !!!!
Logged
Mike Chappell
1985 Eagle Model 10
8v71
Allison Auto
Bossier City La
Ncbob
Guest
Re: Oil Filter
Reply #1 on:
March 01, 2008, 02:14:18 PM »
Psst. Unless it's remote mounted it's on the engine.
Sorry, today seems to be one of my more capricious days....with tongue in cheek.....
Bob
Logged
pete81eaglefanasty
Sr. Member
Re: Oil Filter
Reply #2 on:
March 01, 2008, 05:50:16 PM »
If you have a 6v92 it's on the right side by the transmission. In the picture it is the long white cylinder hanging down.
Pete & Jean
FANTASY
Logged
WHAT EVER YOU DO, OR TO WHO YOU DO IT TOO, DO IT WITH A SMILE, IT MAKES IT LEGAL THAT WAY.
Guest
Re: Oil Filter
Reply #3 on:
March 01, 2008, 05:55:30 PM »
I have seen Eagles with remote mount filters located under the battery inside the door and also at the tail lite door where the power steering filter is located good luck
Logged
Stan
Hero Member
Re: Oil Filter
Reply #4 on:
March 01, 2008, 06:05:52 PM »
In addition to luvrbus' comment, the normal place is on the driver side of the engine beside the oil pan. If you have a muffler there, look up between the muffler and engine oil pan.
Logged
Hero Member
Re: Oil Filter
Reply #5 on:
March 01, 2008, 10:26:09 PM »
On my 8V-71 and V730 the oil filter is remote mounted between the engine and rear axle for easy service when over a pit-like what a transit company would do. After the original filter broke and I found it was almost impossible to service, I took out my radiator and then the remote filter was easily accessible. I then had two stainless braided lines made up so that I could mount a new spin on filter (the old one was a canister type) on the right side of the engine compartment just inside of the right side transmission access door. Now easy to get to and service.
Looking at the front of your engine (where the fan pulley is considered the front of the engine)-as you're looking at it look at the left of the engine below the cylinder head and you should see the engine oil cooler. Typically the oil filter should be either mounted directly to the engine or you'll see two large oil lines coming off of the oil cooler to the remote mounted oil filter. Good Luck, TomC
Logged
loadera10
Newbie
1985 Eagle Model 10
Re: Oil Filter
Reply #6 on:
March 02, 2008, 05:54:12 AM »
Thanks for the info, I will further investigate........
Logged
Mike Chappell
1985 Eagle Model 10
8v71
Allison Auto
Bossier City La
loadera10
Newbie
1985 Eagle Model 10
Re: Oil Filter
Reply #7 on:
March 02, 2008, 06:01:38 PM »
I found it, It was on the right side of the transmission next to the trans filter. Just needed to crawl a little farther.....
Logged
Mike Chappell
1985 Eagle Model 10
8v71
Allison Auto
Bossier City La
JohnEd
Hero Member
Re: Oil Filter
Reply #8 on:
March 02, 2008, 07:13:41 PM »
Pete,
You keep you bus cleaner underneath than I do the uptop part
That is the cleanest engine I have ever seen that was run at least down the block. Is that one of those MYTHICAL DD's that doesn't leak oil? Is it all tuflawn koated?
Nice!
Logged
pete81eaglefanasty
Sr. Member
Re: Oil Filter
Reply #9 on:
March 02, 2008, 07:32:34 PM »
Thanks John.I have no leaks in the DD I do have a small leak in the transmission tho. As far as the slobber tubes goes i installed The tank from DD about 8 years ago, glad I did, Here is a couple of pictures of it.
Pete & Jean
FANTASY
Logged
jackhartjr
Hero Member
Beauty is in the eye of the beholder!
Re: Oil Filter
Reply #10 on:
March 02, 2008, 07:41:59 PM »
Pete, please tell me a little more about that tank...please! Is it vented in some way, and how do you drain it?
Jack
Logged
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
Guest
Re: Oil Filter
Reply #11 on:
March 02, 2008, 07:58:43 PM »
I'm also interested.
Pete you have such great ideas with good results.
Logged
pete81eaglefanasty
Sr. Member
Re: Oil Filter
Reply #12 on:
March 03, 2008, 04:03:21 PM »
Paul & Jack
I've had it for 8 years now and drain it once about 3 years ago and got just a little bit of oil. It is vented through the drain plug at the bottom of the tank. It's about 1" plug with a center breather that goes up the center of the plug about 3" It acts as a breather. Boy I hope I explain it good enough to understand.
Pete & Jean
FANTASY
Logged
Guest
Re: Oil Filter
Reply #13 on:
March 03, 2008, 06:18:29 PM »
Thanks Pete for sharing the information!
Logged
jackhartjr
Hero Member
Re: Oil Filter
Reply #14 on:
March 03, 2008, 07:11:27 PM »
Thanks Pete. I didn't quite get the breather or vent part. If I read it right, it the breather, or vent is part of the drain plug. I am not understanding how a vent can be on the drain which I assume is on the bottom?
Jack
Logged
Jack Hart, CDS
8V71 Detroit
Print
Pages: [
1
2
All
Go Up
« previous
next »
BCM Community
Bus Discussion
(Moderator:
Oil Filter
