Author Topic: let me see if I got this straight.  (Read 9370 times)
Offline chazwood
    • Thekempters
« on: March 05, 2008, 05:25:06 AM »
Greetings.
In short, an inverter allows you to switch back and forth between 24v and 110 or 220v.  Right?
If that's correct, it would seem to me that all the switching between voltage would occur at the box and nearby inverter and only one wire would still feed each appliance. No?
1983 Eagle Bus Model 10
6V92
Thekempters.com
Offline Hartley
Re: let me see if I got this straight.
« Reply #1 on: March 05, 2008, 05:36:43 AM »
No actually... Maybe you should ask WIKI ....
An Inverter electronically generates a higher voltage using a lower voltage power source.
A d.c. Voltage is taken and electronically translated to a higher voltage A.C. voltage.
" Direct Current " to " Alternating Current "
A "Converter" Takes a high voltage A.C. source and converts it to a D.C. Voltage.
Offline chazwood
    • Thekempters
« Reply #2 on: March 05, 2008, 05:40:11 AM »
So inverters are not used unless you have a bank of house batteries?
6V92
Thekempters.com
Offline Stan
« Reply #3 on: March 05, 2008, 05:43:18 AM »
If I understand your question correctly (which is doubtful), you run three wires (hot, neutral and ground) from the breaker panel (very similar to house wiring, but not exactly).  All the switching takes place in the shore/gen transfer switch and internally in the inverter.
Offline chazwood
    • Thekempters
« Reply #4 on: March 05, 2008, 05:46:57 AM »
part of asking an intelligent question.....is having intelligence.
What I'm wondering is how do you go from watching tv on the road to watching plugged into a pole.
6V92
Thekempters.com
Offline JackConrad
  • Orange Blossom Special II
  • Global Moderator
« Reply #5 on: March 05, 2008, 05:49:36 AM »
Chaz,
   Most of us use what is referred to as a ""pass through" inverter. When AC power is available (Shoreline or Generator), the power passes through the inverter. The inverter uses a little of this power to charge the house batteries. If no AC power is coming into the inverter, the inverter draws DC power from the house batteries (12 or 24 volts DC, depending on inverter model) and converts this DC power to AC @ 120 volts. You have to be careful when wiring the AC system because if you feed the inverter AC outpout back into the same circuit as the inverter AC input, you will let all the smoke out of the inverter. And we all know what happens when we let the smoke out.
  The simplest way to wire is to have the shoreline and generator feed a transfer switch. The output from the transfer switch feeds the main AC load center. Individual circuit breakers feed all circuits that are NOT powered by the inverter. In addition 1 circuit breaker feeds the AC input to the inverter. The AC output from the inverter goes to a separate load center. This load center circuit breakers feed all circuits that are powered by the inverter.  This is "my way", I am sure there are other ways to "skin this cat".
   The other option is a small inverter that is located near an appliance such as a TV that has an outlet built into it. The TV is then either plugged into the inverter or into a "standard" outlet.  Jack
Offline chazwood
    • Thekempters
« Reply #6 on: March 05, 2008, 06:03:25 AM »
...........I just let the smoke out of my head. >:(  If the system uses a bank of batteries the gen must be to just keep batteries topped off?  In planning for buried wires for all appliances, is it safe to wire everything to a fuse box like a house, and then invert-convert-extrovert-pervert-red-alert the voltage from there?
« Last Edit: March 05, 2008, 06:15:50 AM by chazwood »
6V92
Thekempters.com
Offline jackhartjr
  • Beauty is in the eye of the beholder!
« Reply #7 on: March 05, 2008, 06:08:13 AM »
"And we all know what happens when we let the smoke out."
Jack, that was a classic!  I will use it!
Jack
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
Offline Ednj
  • Ed & Sue Skiba
« Reply #8 on: March 05, 2008, 06:30:34 AM »
Chaz,
 ;D
MCI-9
Sussex county, Delaware.
Offline JackConrad
  • Global Moderator
« Reply #9 on: March 05, 2008, 06:43:26 AM »
The genset is to keep batteries charged and power items that use to much power to run off inverter(s). You cannot run air conditioners off an inverter when parked (bus engine not running).  Well, you can't run them very long! Also make sure you do not feed inverter Out back into Inverter IN AC circuits.  Jack
Offline chazwood
    • Thekempters
« Reply #10 on: March 05, 2008, 07:20:06 AM »
So. if you're planning to boon dock for a few days in a hot climate how do you handle round the clock air conditioning requirements? Run a gen full time? seems kinda loud.
6V92
Thekempters.com
skipn
« Reply #11 on: March 05, 2008, 07:43:09 AM »
Chazwood,
   There are several ways it all comes down to buget and personal choices :)
   1. Run an extension from the generator exhaust to the top of the roof line on the bus. (there are kits for this)
   2. Install solar panels (done right it will cost some money)
   3. If you will be in low humidity consider replacing one ac with a swamp cooler style. (lower power draw)
   4. Have a big ice chest full of ice and keep a ice towel wrapped around your neck.
   5. Just be hot and misirable and ask "Are we having fun yet?"
   Just trying to be helpful :)
 Skip
Offline JackConrad
  • Global Moderator
« Reply #12 on: March 05, 2008, 07:50:24 AM »
    If you want air conditioning 24/7, Yes. We have found, even in south Florida, that at night the temps drop into the 70s. We turn off the Generator, open the bedroom windows, and turn on a ceilinf fan over the bed (fan funs off the inverter). comfortable sleeping.
    The other thing is to have some soundproofing around your generator. This can be a factory "quiet box" or build by you. A vertical stack also helps reduce the noise level.  Jack
Offline Stan
« Reply #13 on: March 05, 2008, 07:57:31 AM »
Quote
is it safe to wire everything to a fuse box like a house, ....?
With one notable exception. You must run separate three wires (off a single 120 volt breaker) for each duplex receptacle. You cannot split the receptacle with a red-white-black (off a dual 240 volt breaker)  as is used on kitchen counters in a house.
Fuse boxes are pretty much obsolete for house type wiring. Use a single phase breaker panel. I have seen comments that the "code" restricts the number of breakers you can have in a RV. That makes no sense to me, to say it is safer to have two receptacles on one breaker than to have each on a separate breaker.
« Reply #14 on: March 05, 2008, 07:59:23 AM »
I have my bus wired very simply using Square D circuit breaker boxes from Home Depot.  I have three boxes.  First is the main box that has four 50 amp breakers-two for the generator and two for the land line.  I made a plate that slides allowing only two of the breakers to be on at a time to assure not mixing the land line with the generator by mistake.  The second box is the circuits I want running straight off the land line or generator.  This box also has a 30 amp circuit that goes through the inverter to the third box that is powered by the inverter.  The items I have running off the inverter are plugs, rear stereo system (house type), front TV, microwave, toaster oven, bathroom heater-all resistance loads that don't require alot of starting amps-as compared to say an air conditioner (my three roof A/C's are not powered through the inverter).  This has been a very reliable electrical system-although you do have to switch manually between land line and generator service-but then again I don't like the automatic switchers.  Good Luck, TomC
