June 25, 2018, 06:47:03 AM
Author Topic: weight of a 4104 shell guess correctly and win a prize  (Read 8235 times)
Offline 4104bigred
  • Jr. Member
« on: June 04, 2006, 08:24:55 PM »
we have a trucking company looking at hauling our 58  4104 empty shell home and need to know the weight.
Prize to be announced before timmonsville bus rally
thanks
chris
Re: weight of a 4104 shell guess correctly and win a prize
« Reply #1 on: June 04, 2006, 10:01:58 PM »
21,500lbs.  TomC
Offline JackConrad
  • Orange Blossom Special II
  • Global Moderator
« Reply #2 on: June 05, 2006, 04:15:50 AM »
Is the interior totally stripped of seats and luggage racks?  Jack
Offline 4104bigred
  • Jr. Member
« Reply #3 on: June 05, 2006, 07:18:06 AM »
yes the bus is just a running shell ready for conversion. inside is only the drivers seat and the original floor with a second new plywood floor
thanks
chris
Offline gumpy
  • Some Assembly Required
  • Slightly modified 1982 MC9
    • bus.gumpydog.com
« Reply #4 on: June 05, 2006, 09:21:16 AM »
I'd guess about 16,500 without full diesel or water tanks.
Offline Len Silva
    • Leonard Studio
« Reply #5 on: June 05, 2006, 10:11:02 AM »
I'll say 18,500 assuming the AC has been removed.
I think 21,500 was the factory weight of a seated coach with air, don't know if that included full tanks (140 +25 for the AC)
Len
Offline WEC4104
« Reply #6 on: June 05, 2006, 10:32:09 AM »
Based on the age of the coach, my guess is 19,580.
Offline Glenn MC9
« Reply #7 on: June 05, 2006, 12:51:43 PM »
Our "04" is set up as and entertainer. I run it across the scales last year with a full tank of fuel and no driver.
Weight: 20,960 lbs.
Glenn
Tallulah Falls, Ga.
1959 PD-4104-4095
1984 MCI-9
1984 MCI-9 (Jersey Cruiser)
6V92-TA/Alison 740
Tallulah Falls, Ga.
www.tlmmusic.com.
Everywhere I go.....there I am.
Offline phil4501
« Reply #8 on: June 05, 2006, 01:05:21 PM »
16,885.5 lbs dry
« Last Edit: June 05, 2006, 09:45:00 PM by phil4501 »
Offline gm4106
« Reply #9 on: June 05, 2006, 01:34:31 PM »
My guess is 16,350
GM PD4106-1689 8V71TA  V730
Mount Holly,NC
Dallas
« Reply #10 on: June 05, 2006, 02:34:50 PM »
I'm closer than anyone else:
It weighs more than I can lift without singing high notes forever after.
It also weighs more than I can push to the nearest fuel stop if it runs out of fuel.
It weighs enough that if the suspension loses air while your under it, it's gonna leave a mark.
Question:
Is this a running coach? By running, I mean is it driveable for long distances?
If it is, why not drive it or hire someone to drive it to it's destination.
If it isn't, what would it take to make it so?
Just some thoughts.
Dallas
Offline Danny
  • 87' MCI 102A3 - getting there...
    • Personal Web Page
« Reply #11 on: June 05, 2006, 03:27:53 PM »
17,200  dry weight
I have heard it said, "life comes at you fast".  I didn't know it would be in the shape of a bus  :-)
Offline JackConrad
  • Global Moderator
« Reply #12 on: June 05, 2006, 04:35:01 PM »
My quess 18,107.  I agree with Dallas, I would look into driving it if at all possible.  Jack
Offline 4104bigred
  • Jr. Member
« Reply #13 on: June 07, 2006, 05:24:55 PM »
OK OK OK OK
I guess my 17 year old son Karl and I will make the trip from michigan to louisiana to drive the bus home. however b 4 we can start for home in bigred we need to do some work to the throttle cable. any ideas with what to do to it to make it work more freely would be a big help.
I do know that the inner cable is nearly new as it was replaced 4 years ago when the bus was purchased by the man we just bought it from. someone suggested to soak it in diesel fuel overnight another idea was engine oil.
what do i do to clean out the outer tube in the bus and how do i lubrcate the cable as i re install? ???
btw i am guessing about 17,500 pounds for the shell and will weigh it at the first cat scale i find
chris ???
Offline FloridaCliff
  • "The Mighty GMC"
« Reply #14 on: June 07, 2006, 05:30:15 PM »
18,235
Cliff
Mark Twain
