June 24, 2018, 04:33:27 PM
Author Topic: 24 Volt System or 12 Volt System?  (Read 4788 times)
Offline cpschevy
« on: March 11, 2008, 09:38:27 PM »
I was wondering if anyone has switched there bus electrical system over to a  12 volt starter and alternator system? I know there is some solenoids and lots of relays to change but is there really that much else to change? I just don't like 24 volt systems, we changed our Big Bud 650 tractor over and it was simple. I figure all the lights are 12 volt anyway so why not simplify the system and make everything 12 volt.            Thanks for your help            Chris
Offline tekebird
Re: 24 Volt System or 12 Volt System?
« Reply #1 on: March 11, 2008, 10:11:45 PM »
hmmm probably most of the wiring.
why would you want to do such a thing?
Are ya skeered of 24v
Offline cpschevy
« Reply #2 on: March 11, 2008, 10:19:10 PM »
No not scared just dont see any reason to have both 12 volt and 24 volt systems in there when its not necessary and it just makes more work with your charging system when you add your house batterys.Also if you have everything 12 volt you could use your house batterys to start your bus in a emergency with the simple flip of a switch or relay system.
Offline tekebird
« Reply #3 on: March 11, 2008, 10:21:44 PM »
much easier to make a 24 volt house system
« Reply #4 on: March 11, 2008, 10:25:33 PM »
Probably because of the big blowers on the A/C systems of the buses is why they have 24v systems.  I can tell you that all American trucks are straight 12v.  They were thinking on changing to 48v or 56v under power (4-31's in series instead of parallel) for engine computer, but the engine companies have beat the truck manufacturers to the punch by having either a built in converter or inverter (Cat uses 120vac) to punch up the juice.  Personally-I really like having a straight 12v wired bus-including the starter.  Makes for much more simplicity.  My truck does have a 24v starter, which would be easy enough to switch over-but haven't had much problem with it.  Good Luck, TomC
Offline jjrbus
  • MCI5C/N Ft Myers FL
« Reply #5 on: March 11, 2008, 10:35:24 PM »
 When I researched this I decided it was quicker, eaiser, cheaper to go to a 24V house system. I'm happy with that decision.
Offline cpschevy
« Reply #6 on: March 11, 2008, 10:36:24 PM »
Hi Tom , I am probably not going to use the bus A/C so i dont think i need 24v cause that is the biggest need for it. I just think the 12 volt systems are more common and easier to deal with when you need a jump start. thanks for your input.
Offline tekebird
« Reply #7 on: March 11, 2008, 11:07:51 PM »
unless you plan on rewiring the whole coach....some 5 miles of wires.....just go witha  24 volt system....save yourself alot of headaches tracking down problems.
24 volt system wires are going to be too small to carry 12v
the main reason they use the 24volt is the cost of copper
Offline Sean
  • Geek.
    • Our Odyssey
« Reply #8 on: March 11, 2008, 11:56:43 PM »
... I figure all the lights are 12 volt anyway so why not simplify the system and make everything 12 volt.
Chris,
I think you'd better re-figure.  If that's an MCI I see in your photo, all the lights are 24-volt except the headlights.  Here is a partial list of what you will have to change, starting with the most expensive items:
  • Starter
  • Alternator
  • Tail, brake, turn, and marker lights
  • All gauges except air pressure
  • All dash illumination
  • All warning lights and buzzers
  • All relays
  • All the wire to all the lights and some of the controls (wrong gauge)
  • All battery cables (wrong gauge)
  • Alternator and starter wiring (wrong gauge)
  • Likely some engine sensors and harness wiring.
I'm sure there's something I've missed, and I am equally certain that after you're "done" with such a project, you will only then find out something you've missed, too.  If you're lucky, it will just not work -- if you're not so lucky, you could have a fire, fry something expensive, or worse.
In short, I think this is a fool's errand.  Also, 24-volt systems actually make much better house systems, as has already beed suggested to you.  You get to use smaller wire for everything, which really helps with the big stuff like inverters, you can get bigger inverters in 24-volt, and it's easy to transfer power from the alternator to the house system, or, if needed, the house system to the starter.  There is really only a small handful of electrical items that are only available in 12-volt and not 24.  FanTastic fans come to mind, along with LP alarms, and the control boards of RV appliances.  For these minimal loads you can center-tap the batteries and add a small equalizer -- waaaay cheaper than trying to change your bus over to 12 volts.
FWIW.
Sojourner
« Reply #9 on: March 12, 2008, 02:45:53 AM »
Amen to all above posts!
Example…..back in the old days before 1955, it was all 6 volts in cars and light trucks and farm tractors. Whenever we start our vehicle it was always common to cranking fast enough to get it fired or run the battery down. But since 1955…the 12v came out….wow….it begin to take away the fear of not firing to running everyday.
Liked what TomC said that 42v is in the planning stage to be release to the public soon.
This is even better for starting as well smaller wiring and faster turn on lighting & accessory. They say that new system will be design to kill engine at stop light and restart as soon you depress accelerator pedal like does in gasoline power golf cart now. It to save on fuel usage.
By the way…most farmers went to 8 volts battery to starts 6 volts tractor in colder climate.
24 volt system is your low cost way to go due wiring (smaller gauge) already in your coach.
FWIW
Sojourn for Christ, Jerry
PS…..Thanks Sean for so well written and informed reports.
Offline Tenor
    • Three Men and a Tenor
« Reply #10 on: March 12, 2008, 05:28:35 AM »
Chris,
All of the reasons for why not to get rid of your 24V system are about why the disadvantages to switching, but you need to also be told of the positive reasons for keeping it.  If your bus air conditioning is toast and you plan to remove it, how were you going to cool it while going down the road?  Genset?  Diesel or gas?  How about this - get a Xantrex SW 4024 4KW inverter (it is a 24V model), run it from your bus alternator, and run 2 roof air conditioners while driving.  No extra tank for a gas genset,  no fuel loss to run a diesel genset.  Just add 2 group 31 start batteries to your bus, and use the 2 big 8D's for your inverter.  Of course at some time you would want to upgrade the battery type, and maybe expand the bank, but that's not what this thread is about.  Good Luck!
Glenn Williams
Lansing, MI
www.threemenandatenor.com
8v71
4 speed Spicer
Offline BEN MC7
  • It is about time to finish this project....
« Reply #11 on: March 12, 2008, 05:48:33 AM »
Well, I guess my question to you would be, what kind of condition is the electrical system in that is presently installed in your bus.  I switched my bus electrics to 12V (including the starter and alternator) almost 10 years ago.  Of course, the system that I had in the bus looked bad and the panel near the driver looked like a drunk bus employee was working on the wiring and it was just ugly in general.  As a result, I pulled all of the bus wiring out of mine and started fresh with boat grade electrics and tinned wire. There is a bit of work to any bus that you don't know the history of repairs on and by installing your own system you know what is connected and what isn't.  It wasn't that difficult to get done, just time consuming and many many rolls of wire.  And as a result, everything works and the possibility of a short due to the 30+ year old wire or poor prior repairs is eliminated.
Offline H3Jim
« Reply #12 on: March 12, 2008, 07:44:41 AM »
FWIW,
I made my house system 24 volts, kept the bus system at 24 volts.  I'm very pleased with the way it has all worked out.  I would say if you have to replace it all anyway because its bad or dangereous, have at it, but if it works, why fix it.  It sounded like your main fear is needing a jump start and not being able to get it.  If you have a 24 volt house system you're all set and can jump yourself.
And with a 24 volt sytem, if you need to jump start your truck, boy will that sucker spin! (just don't have anything else turned on or you will  fry  it)
« Last Edit: March 12, 2008, 12:14:21 PM by H3Jim »
Jim Stewart
Offline DrivingMissLazy
« Reply #13 on: March 12, 2008, 11:36:39 AM »
FWIW,
And with a 24 volt system, if you need to jump start your truck, boy will that sucker spin! (just don'e have anything else turned on or you will  fry  it)
Several years ago I was deeply involved in building sand rails for use in the desert. The common engine was either a VW or Corvair.
On all of these vehicles we installed a 6 volt starter with a 12 volt electrical system. That really cranked the engines over fast and made for good starting. In all the years doing this, I never had a starter failure and have not heard any of the other people doing this having a starter failure.
Dallas
« Reply #14 on: March 12, 2008, 02:38:07 PM »
Richard, back in the late 60's and early 70's we did the same thing with the VW's. The problem we had was that the ignition coils would fry. even if we used a 12V coil with a condenser, we could plan on a replacement at least once every few days.
